I would say the 30T and Sofirn 4000 are pretty much similar in this particular test. I think the emitters and circuit are starting to max out. We might see the 30T gain an advantage again if we swap out the skinny driver bypass wire with an 18ga. I’m guessing here.
If we go back to the skinnier stock led wire test, we see the 30T has a definite advantage with about 0.4A and 200 lumen more. So it is the better cell when it comes to high amp loads and having lower internal resistance. Dale has used a pair of 30T on a triple xhp70.2 light and they drew about 48A-50A. I don’t think the Sofirn 4000 would do as well in this extreme test.
Also, I did this last set of tests pretty fast and the light only cooled down for maybe 2 minutes between each pull. It’s not ideal, but still gives a pretty good idea of the differences.
We also know the Sofirn 4000 is not a 40T. It’s made in a different factory (in China) for the electric vehicle market. It’s definitely a good cell. Maybe it’s a Lishen LR2170SA 4000mah? The Liitokala 4000mah 21700 is a rewrapped Lishen and this cell performs really well also. I don’t know, but they do seem very similar.
Yes, very throwy lights do measure even higher with his tube. I think I found his tube sometimes measures between 8% to maybe 16% higher than mine on average.
He may know a few other tricks to boost output as well. Like using warm batteries fresh off the charger. I’ve heard warming up the batteries gives them some extra oomph. He might replace the lenses with UCP which have lower losses, etc… Dale just gets all the highest output. I can’t compete with him. He’s the king! Lol
Probably should send Sofirn this info so that they can improve the wire gauge being used and increase the lumens output to the correctly stated lumens (C8F 21700 stated to be 3500 lumens, and so far the stock form varies from around 2300-3000 lumens based on these user reports in the forums, which is way short of the “3500 lumens” claimed output.
I mentioned that I sent Sofirn this info in post 56.
They probably should just reclassify the light as 3,000 lumen. That would be more accurate.
The only real change between the 18650 version and the 21700 version is the battery size. It doesn’t make sense that a battery change alone would give you an extra 1000 lumen. An increase of about 500 lumen is much more realistic.
I hope they change the wire size, then they could rate it above 3,000. A real hotrod then.
I’ve been working on and off on trying to figure out how the switch light circuitry works, but so far I’m at a dead end. It’s certainly not a traditional switch light setup that uses two different color LEDs. On those you typically have one wire that acts as a common ground or common positive and then three more wires for the switch and two colored LEDs. The C8F has a switch, two colored LEDs and uses four wires, but the design is very different. Maybe someone here that knows more about electronic circuits can figure it out. Here is what I have so far.
A couple of the circuits.
Wire #3 does not go to ground to make the red led light up.
Both red leds are wired in parallel. Both green leds are wired in parallel.
Here is the basic led circuit minus the switch stuff and the duplicate leds. This is the most up to date.
If anyone can make sense of it, please let me know.
Sofirn Samsung is very kind. They had a brand new C8F 21700 shipped to me from Amazon for free. I was shocked to see the label titled to SKV89 and was wondering what the heck could be in the package. The output, unfortunately, measures the same as the output of the one I bought originally from Aliexpress and is also the same as the output after swapping in the free replacement driver into the Aliexpress C8F 21700.
Regardless, I sincerely appreciate Sofirn’s generosity and excellent customer service.
You should try the new Sofirn SP33 with xhp50.2. It has a little bit larger hotspot. Nice 26650 size. The boost driver kind of spoils me due to it’s consistent output and low heat production. It has replaced my C8F.
Received my new order and it is disappointing to see no change in output. The plus side is the thermal sensor making it safer and more user friendly for my customers.
I get no higher than 2650 at 30 sec
It’s puzzling as to how they got 3500 lumens. Their ratings are usually not that far off. I see d_t_a mentions a wire gauge change boosts lumens a fare bit. I’m not going to bother as that would be a big hassle to perform on all of them
The manual states it steps down at 50C but I just ran a test and it kept on Turbo until I had to turn it off from the heat. It was too hot to touch on the head and top of battery tube. My 30Q was very hot. It was maybe 65C and still no step down
What’s everyone else’s experience with this?
I was in ramping and in Turbo. This one might have a fault?
EDIT: just tried another C8F with the same result but measured the temp and it was still climbing at 56C with no step down. The whole light was around the same temp and battery at 45C. Why don’t they step down at the specified 50C?
EDIT 2: Ran another test on my lumen tube and let it run slightly longer this time. Turns out it steps down at 58C to 800ish lumens. It felt scary hot though….I think I may have peed a little
Yeah, they should have stuck with the same rating as the 18650 version which was about 2570 lumen or so.
FET drivers are greatly effected by resistance in the circuit which includes the battery, driver pcb, the FET, the LED, etc… There is just some extra resistance somewhere that’s reducing the drivers full potential.
Still, I don’t mind 2600 lumen. It’s bright for such a small light, plus you can run it longer at that level compared to if it was 3500 lumen. It’s ehh, whatever. Having a nice user interface is more important to me. I find the new Sofirn SP33 to be better than the 21700 C8F.
I should be receiving the SP33 later this week! looking forward to it.
It certainly is enough light for the C8F. The 18650 version at 3100+ lumens just got way too hot on Turbo for practical use. It’s quite nice having no step down timers as well.
I am currently trying to get a 22mm TA driver working in my C8F host. I am trying to figure out with trial and error which two wires of those four let the momentary switch work. Can anyone help me to solve that problem or do I need a new switch? Maybe I already killed the switch lights but they are not that important for me.
Thanks for telling me. I would have needed to try all combinations otherwise. Do you know where I would need to cut traces to get the switch leds working? In the mean time I will try to solder the black and white wires.
I show all the circuits a few posts above. You’ll need to replace the double leds with single units, cut a trace then solder a jumper wire - I think. I’ll have to look at it later tonight.
