I’m interested in 3d printing for years now and since it gets more and more affordable I bought my first cheap printer this summer. I tinkered with electronics and software all my life (privately and commercially) and this 3d printing actually offers many oportunities I was missing the past years - particularly since my hand crafting skills and my patience are somewhat underdeveloped. And I have 2 kids who are also interested in this and other technologies.
My first 3d designs I created with Tinkercad which is great for beginners. But soon I was missing advanced options which I found in Fusion360 (free for private use). Tinkercad is easy to learn, Fusion360 is not due to its unique user interface. I had a hard weekend with much cursing and swearing when starting with this software, although I’m a software engineer by myself.
Its pretty easy and encouraging to create and print the first simple designs, and if you learn rather by doing than by reading you should try it. For advanced designs and more beautiful prints you have to do lots of reseach though - but there are many sources of knowledge and many people eager to help, just as in BLF.
In addition to a design software you need a slicing software which prepares the designed object files for printing. It “simply” calculates the path the print head has to go. Currently I use Cura and Slic3er (no typo), they are good but not perfect, and for better results there are many tuning options. Both are free.
I’ve finally sucessfully printed all large and most of the smaller parts. Since I modified the design and made upper and the lower casing two parts each I was able to use the green ABS for the shells as primary intended. The blue components are made of PETG which is also more heat resistant than PLA.
And I assembled the light the first time right now. Electronics not yet inside. Don’t mind the orange thing in the middle, its just a printed placeholder for the final copper disk which I still have to drill and file. Did I mention my missing handcrafting skills and patience? Fortunately only a small ring of the copper can be seen in the final build so hopefully people don’t notice my handcrafting disability …
Closed lantern:
Opened:
Bottom view (the orange triangle is a printed tool for dis/-assembling):
The electronics compartment. You might notice that the bottom plate has threads at the outside and in the center. This should ensure the o-rings pressed tightly for proper water protection. Magnets still missing, haven’t arrived yet.
Thanks! Its 102 mm in diameter with a height of 56 mm closed and 130 mm fully extended (excluding the lanyard mount on top).
And it already feels more heavy than expected. I guess it will be about 400 grams finally with copperplate and cells.
Well, the circular 20x2 mm magnets are still missing. Yesterday I ordered other ones locally from Amazon, they should arrive tomorrow. These are smaller though, only 15x2 mm. Dependent on which batch arrives first (if any), I have to reprint the bottom plate.
Managed to finish the copper disc. Not too beautiful but functional. Was a pain, hands and arms do still hurt. Only minor injuries though …
I borrowed a step drill from a friend for the 28 mm center hole. For the small holes and the first steps of the center hole I used a small hand drill until it’s cells were empty. Didn’t want to wait for charging, so I took my fat and heavy hammer drill for the last steps. Both without drill mount and bench vise (which I don’t own). I screwed the copper disc on top of a wooden block before in order to be able to keep it in place with one hand.
There are still some smaller parts to print, I hope I’ll finish printing today.
Must look worse in person. It looks fine to me, in the pic. In fact, I can’t find anything wrong with it. It looks like a manufactured part.
How much filament does it take for the bottom plate? If it isn’t too costly, you could go ahead and print the other plate, so that when your magnets arrive, you will be all ready to use whichever size you get in hand first.
Well, my sense of self is somewhat damaged after watching too many of CRX’s builds (which are pure perfection).
Its not a question of costs, less than 50 ct for the plate. But I don’t know how strong the magnets are. I would rather like to check first how many of them I need for the lantern before I do the redesign and printing.
Finally got the locally ordered magnets. Designed and printed a new bottom plate and the disks which cover the magnets. Glued magnets and disks in.
And I assembled the upper part of the housing.
I married upper and lower part. The clear battery holder is - like the green components - made of ABS. All parts touching the hot copper disk are printed with ABS filament now which should withstand temperatures up to 100 °C. All other parts are PETG with a heat tolerance of up to 70 °C. The RGB status LED and the USB-Connector are glued in and sealed and should provide water protection.
I checked driver, bluetooth transmitter and charging board, everythings works well of so far. Tomorrow I will put the electronics in the housing, too tired now, its after midnight here. Hopefully the lantern will be completed tomorrow, I need the last day of the contest to make a video showing the remote function.
