2D Maglite Tri XM-L U2 1C **PIC HEAVY**
34 posts / 0 new
jufran88
jufran88's picture
Last seen: 3 years 5 months ago
I been planning this build for quite a while now, but never got around to actually building it til now. I got the idea for a triple XM-L from threads over at CPF and decided it would be a cool build to make. I originally planned on using a sandwiched AMC7135 driver to reach 3A and just adding a resistor inline to the switch to drop off the extra voltage so the drivers wouldn't heat up so much. Luckily, kaidomain had some new drivers on their website that would better suite my purposes. Thumbs up to Angelos for showing me those drivers!
Specs:
Tail cap readings:
Freshly charged 2 x 26650s after 30 minute cool down.
High: 3.75 A
Med: 2.06 A
Low: 599 mA
Light output testing:
Testing was done in a dark room. Lumen output was done using the light box method. There is still a degree of error using this method so take it as an approximation.
  • Light box lumens:
    • 1923 lm on high @ 1 sec
    • 1792 lm on high (stable)
  • Ceiling light bounce test:
    • 212 lux on high
  • Lux @ 1 meter:
    • 12000 lux on high
Flashlight pics:
LEDs wired in series
Beam shots:
I'll have some outdoor beam shots up soon! Hopefully these will suffice for now. Smile
These shots were taken about 7-8 feet away
Final thoughts:
Definitely one bright light! It's hard to tell from the pictures and in person, but it beats the DRY on high. The hot spot isn't as nicely focused using the LEDIL Boom reflectors, might do another build using the extra DRY driver I have and a triple head reflector like the DRY's. The 1C tint is pretty nice, but for some reason it shows up kinda greenish on some pics. Gotta love these Maglites! They're so moddable, they should be called Modlites! Beer
Thanks for looking!
Edited by: jufran88 on 03/14/2012 - 03:12
Hill
Hill's picture
Nice build.
How do you fit 2x26650's into a 2D?
My lights here and here
dthrckt
dthrckt's picture
nice light.
where did you get the heatsink, and could you link the driver?
____________________
Girls can shoot!
ruffles
ruffles's picture
Awesome! Would also love to hear about all your parts, though I suspect "I own a lathe" will come up.
Aside to oldbobk: if you hit the 'post reply' button at the top left of the original post, then you won't end up quoting all the pics (which is hard on the bandwidth).
N.Shock
Last seen: 3 years 1 week ago
Very nice build! I really like it and I'm interested in a part list too.
joe1512
Last seen: 7 months 4 days ago
It probably has even higher actual lumen counts.  The TK70 runs at 3 amps each and hits 2200 otf lumens.   This one approaches DRY levels (likely with better efficiency due to nicer parts) so I'd think it would hit 2500ish.
JohnnyMac
JohnnyMac's picture
Last seen: 1 year 12 months ago
Great job!  One day I will build one of those.
I find it interesting that it's brighter than your DRY.  Your light is pulling 2.5A/LED at the tail while the DRY are pulling anywhere from 3.2A-4.2A/LED.  It has to be the reflector shape focusing more light into the center making it appear brighter.
jufran88
jufran88's picture
@Hill: Thanks! I used a fiberglass sleeve made by LPF member jayrob
@dthrckt: Thanks! I got the heatsink from download at CPF last year, this build has been pending for a while heh. Here is the link to the driver: http://kaidomain.com/product/details.S020077
@oldbobk: Thank you! It's actually a more neutral color to my eyes, but the camera turns it kind of greenish. Your right most likely medium is all I need. The high setting is more of a wow, that's bright mode, heh.
@ruffles: I wish I owned a lathe! I would love to make my own heat sinks, but I'm kind of out of budget for that right now =[ I got the heat sink from download @ CPF last year.
@N.shock: Thanks! I'll update the parts in the specs section with links!
@joe1512: I would like to think so, that would be awesome!
@JohnnyMac: Thanks! On high it beats the DRY, but on turbo the DRY is the clear winner. Running the ceiling bounce and light box test while both on high, the Mag got the higher numbers. Probably better efficiency since it is a U2 bin vs the T6 bin in the DRY.
dthrckt
dthrckt's picture
thanks jufran
any chance of you trying the light w/ one real and one dummy cell?  I know it should go into low voltage protection mode - but I'm wondering if cycling on/off twice will disable that.
Girls can shoot!
jufran88
jufran88's picture
I just tested this out and it does work! When you turn it on it will go into protection mode and flash, but if you cycle through it will bypass the protection and I was able to get it to work normally.
dthrckt
dthrckt's picture
that's awesome - and means someone smarter than I am might be able to figure out how to disable the protection.
any idea what kind of output (watts) you were getting?
Girls can shoot!
jufran88
jufran88's picture
I Estimate around 22 Watts. I took apart the light to do this and get the Vf and I. :bigsmile:
dthrckt
dthrckt's picture
wow, that's great - I hope someone will figure out how to permanently bypass the protection - though it is kind of big to fit in single cell lights...
edit - wait...so you were measuring output too LEDs and not input to driver?  did you measure input, too?  because if it has decent efficiency w/ one cell.....even better!  thanks!
Girls can shoot!
atbglenn
atbglenn's picture
Wow! nice work!
Boycott Nike
jufran88
jufran88's picture
@dthrckt: Wait, I think I'm lost.. Yes, I was measuring output to LEDs with 2 cells. Measuring input wattage to the driver? Hmm, that would be batteries voltage (under load) x tailcap current = 7.78 x 3.75 = 29-30 Watts?
Calculating for efficiency using Vbatt x Ibatt x Efficiency = Vf x If
Efficiency = (Vf x If) / (Vbatt x Ibatt)
Efficiency= (9.2 x 2.4) / (7.78 x 3.75) x 100 = 75.68% efficient
Not calculating other losses such as internal resistance on the switch and tail cap.
@atbglenn: Thank you!
dthrckt
dthrckt's picture
that's what I meant (output, input, efficiency)
but i thought you were getting 22 watts to emitters with ONE cell Smile  which is why i was pretty excited lol
anyway, 75%  beats the pants off the last driver I tested efficiency on
Girls can shoot!
jufran88
jufran88's picture
Ahah, sorry about that. Embarassed The driver could be around 80% efficient if you factor out the resistance from the tail cap, switch, wires.
dthrckt
dthrckt's picture
if you don't mind I'll fwd a link for this thread to ian mander.  he maintains this driver db http://www.videofoundry.co.nz/ianman/laboratory/research/driverlist.php
so, would you say (at least visually) you get decent output w/ the single cell?
Girls can shoot!
jufran88
jufran88's picture
I don't mind! I say there is a bit of decreased output with only 1 cell, but it does work. It draws about 2A on a single cell.
dthrckt
dthrckt's picture
ok, i'll email him.
thanks, for the info.
Girls can shoot!
Lothar
Lothar's picture
Last seen: 20 hours 53 min ago
@dthrckt: Apparently you can just ask Kaidomain and they'll send you one without the low voltage protection - http://kaidomain.com/product/browsediscussions/111
@jufran88: Great build, thanx for sharing! Is it possible you can perhaps test the light with 2 x 18650's and let us know if they can supply the same level of amps than the 2 x 26650's. Also, which Ledil Boom reflector did you use (S/M/W) and where did you get them from?
Current Collection: BTU: Shocker (3 x SST-40 @ 8A)Lumintop: BLF GT70 (CW Sliced), BLF GTmini; Solarforce: 2 x L2P (XM-L2 U3 2C @ 4A), MPP-1 (XP-L HI @ 6A), MPP-3 (3 x XM-L2 U2 2C @ 12A), M6 (Nichia 319A @ 6A), M8 (Cree XHP-50.2 @ 9A), 9x (9 x XM-L2 U2 1A @ 2A)
Coming Soon: Lumintop: BLF GT4; Sofirn: BLF-LT1;
dthrckt
dthrckt's picture
I will probably try that!  thanks for letting me know.
and yes, thanks again jufran for sharing.
Girls can shoot!
mattthemuppet
Last seen: 1 week 1 day ago
if you want a tighter spot, the Ledil Reginas work well with XM-Ls, you just have to hand ream out the hole to 7-7.5mm first. I've never actually used a Boom SS (although I have one in my bits box) but I've used Reginas a lot. I personally don't much like the bright spot/dimmer spill of reflectors, so I've moved over almost entirely to TIR optics for my bike lights (different requirements though), but the Regina is one of the best throwing 20mm reflectors for XM-L.
oh, great build too BTW Smile
Old-Lumens
Old-Lumens's picture
Last seen: 2 years 11 months ago
Nice clean build, thanks for posting this.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
viktori
viktori's picture
Last seen: 3 years 2 months ago
Wow, really nice buid!
A question, though, can you edit your original post and include the links for reflectors and lens (and any other parts sourced from the net)?
More pics of the pill and the assembly would be nice too. Wink
Thanks for the post!
Viktor
This is my flashlight collection.
jufran88
jufran88's picture
Sorry guys for the late responses. I been away and just got home from work. I have gotten some outdoor shots when me and my girlfriend went up Mt. Hamilton for a drive. I also got some outdoor shots of my DRY. I'll post a comparison later.
Here they are!!
High (Sorry this was the first shot I took and didn't notice it was blurry)
Med
Low
@Lothar: I'll try it! I'll post up some info when I get the chance to do it! I used the Boom MC-E spot reflectors. The OP has been updated with the link! Beer
@mattthemuppet: Ooh, I might try that. It seems its a bit longer than the Boom reflectors, so maybe I need to trim the inside so the heat sink can sit lower. I noticed with these boom reflectors that there is some light escaping the bottom so I'm losing a little bit of output there.
@Old-Lumens: Thank you!
@viktori: I will update it!
fishinfool
fishinfool's picture
Wow!  Very nice!
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
jufran88
jufran88's picture
@fishinfool: thanks!!
I forgot to add this picture Embarassed
It just started sprinkling when I started taking these pictures.
Foy
Foy's picture
Last seen: 4 years 7 months ago
This is an awesome build.
jealousFoy
No referral links and nothing embedded . . . ever.
                      &nbsp
jufran88
jufran88's picture
thanks foy!  Smile
ruffles
ruffles's picture
I thought the squiggles in the pics were the other, littler, photons getting scared away by the big boys. Great build, and thanks for sharing all the details. This is the sort of thing I'd love to do. Just gotta claw through a few other pending projects...
