I picked mine up yesterday. Its a VERY nicely made light. I like or can live with just about all its “quirks” like the odd UI, but im not very happy with the beam pattern it produces.
Mine has a smooth reflector, and the tint shift is truly a CREE rainbow. I can visually see at least 3-4 steps of color transition. I could probably live with that, but the thing thats bothering me the most is that the hotspot is a donut with a dim spot in the center.
I only paid $20 for mine with a coupon from Amazon, but im not 100% sure I want to keep it.
Each code is one time use, you may be able to buy more than one in your order but only one amazon order will process. Try adding one a at time into the cart then go to checkout and add code.
You need to join the Vipon but all that they want is valid email, can be throw away yahoo,gmail, etc.
They have lots of good codes and it is all for Amazon, easy peasy.
Thanks much Keith but the code isn’t working. What a wonky site that vipon is! It took forever to join and at first it wouldn’t let me navigate the site unless I downloaded their app. After much frustration, I finally got through to get the code.
Went to Amazon but the code is no longer any good.
Awesome, thanks for sharing. I’m ok with my current LED, but have been keeping an eye out for something else… LH351D, Luxeon V2 (waiting for reviews of that), etc.
Looks like they reactivated it with price .01c different which should be good now.
I always used the site with desktop so have no idea of mobile app.
Anyway try again.
I may see if it will let me buy another with new code for gift for my brother.
Update; Just tried it and……NOPE, once you buy with vipon code with amazon you are locked out from doing another purchase even with different code on same item.
So stock up on original purchase or use another members account.
Great little light with big output, does have pwm on low but still excellent aaa flashlight for less than $5, now will only let you order 1 of these, oh well was good while it lasted.
Just received one of these from Amazon using the coupon for $19.95.
That price, the positive review, and the bunch of unused 14500's sitting in the drawer, are what convinced me.
There is a lot to like here.
Some random observations tho:
To keep the provided USB-charging 14500 at nominal capacity, the overall length of the cell is increased considerably in order to fit the charging circuit. This works fine in the E05 as it is designed to accommodate the extra length, but not so for re-using in other lights you may have on hand. My ancient AW protected 14500 works just dandy in the E05.
I wish it had come with an OP reflector as the beam pattern is a little rough with the smooth one. Not being inclined to mod, I can live with this though.
The light came with the battery pre-installed and charged to mid capacity. To do this, they must have some confidence that parasitic drain will not deplete the battery before it reaches the customer. Wondering if it has been measured.
I am not a fan of the magnetic end cap ... or magnets in general for anything intended for EDC. Keep them away from your mag-stripe credit cards, work ID/access cards, and the like!
Thanks for your thoughts schuster. I’m awaiting the arrival of mine. Looks like a great deal for $20.00. I actually prefer the magnet as I find it increases the usefulness of smaller lights but to each their own.
Like you, I prefer OP reflectors in lights unless it’s a dedicated thrower. I’m thinking if the beam bothers me, an application of diffuser film will clean the beam up. I use it in a lot of my lights and it’ll turn a smooth reflector into a OP.
Thanks for pointing that out.
Guess I will have to look, as it is not clear to me whether the magnet acts as a spacer beneath the rear contact; i.e. if removing the magnet will change the effective length of the battery tube.
Thats a good question, but if it does change the length, I bet you could just shim it where the magnet was with some scrap plastic/paper/etc (maybe a couple layers cut from a junk-mail credit card or gift card?)
Mine finally arrived. What an great little light for $20.00! The best 14500 light I’ve ever owned and I’ve owned a ton of them. The accessories you get with it makes it an even better bargain. The only minus I can come up with is the low capacity cell it came with but that’s easily corrected and it’s fine for now.
The tint on mine is fantastic! No need to change this emitter. I’m biased towards CW and this thing is great. Pure white corona with beautiful spill. No tint shift on this, just beautiful pure white with no hint of blue or green at all and no artifacts at all, at least in this example. I really won the tint lottery!
To say I’m happy with this is an understatement. Wonderful build quality as good as any light I’ve ever had. This would be a good buy at it’s $39.99 retail but at $20.00, it’s an incredible bargain!
P.S. Thanks again Keith for alerting me to the 50% off code.
I’m running those Soshine yellow/white 14500. 900’s for a while now.
in several lights.
They give good run times and plenty of output power.
2 x Jetbeam and a Sofurn.
Compliments of Bangood early this yr.
Higher output than the Pana’s I have.
