Lumintop Tool AA 2.0 is a portable mini AA flashlight, which is the upgrade version of bestseller Tool AA. With the incredible handy and compact size, it emits a max output up to 650 lumens with the compatibility with one 14500 rechargeable Li-ion battery. Four output levels for various lighting demands, and additional Strobe for emergency situations. The included diffuser makes it best for reading, campings and so on by creating a soft and pleasant beam. There are two tail versions for options, tail switch and magnetic, capable for tail standings to serve as a candle or magnetic suctions on a metal surface for different position lightings. Two positions body clip offers various wearing manners, such as clip on your pocket or on a cap to free your hands. Tool AA 2.0 is essential for camping, touring, home using, gifts, EDC gears, and emergency lightings.
Main Parameters:
LED: Cree XP-L HD LED
Power Source: 1 × AA or 1 × 14500 rechargeable Li-ion battery
Max Output: 650 lumens
Peak Beam Intensity: 3420cd
Peak Beam Distance: 127 meters
Waterproof: IP68
Impact Resistant: 1.5 meters
Output and Runtime:
● Powered by 14500 Li-ion Battery
Low: 16 lumens ( 37hrs )
Med: 85 lumens ( 6hrs 9mins )
High: 360 lumens ( 1hr 19mins )
Turbo: 650 lumens ( 33mins )
Strobe: 360 lumens ( / )
● Powered by Alkaline Battery
Low: 3.7 lumens ( 2.5 days )
Med: 25 lumens ( 11hrs 50mins )
High: 140 lumens ( 49mins )
Turbo: 220 lumens ( 21mins )
Strobe: 140 lumens ( / )
● Powered by Ni-MH Battery
Med: 25 lumens ( 12hrs 30mins )
High: 140 lumens ( 2 hrs 33mins )
Turbo: 270 lumens ( 43mins )
Product Features:
● Utilizes XP-L HD LED with a lifespan of 50,000 hours.
● Powered by one AA or one 14500 rechargeable Li-ion battery.
● Two ways to select outputs: Tail switching or twist the head.
● Four output levels plus Strobe with max 650 lumens output.
● Mode memory function recalls the last use output when turning on next time.
● Super long runtime up to 2.5 days in Eco mode.
● The optional magnetic tail cap is capable for tail standing to serve as a candle.
● Light-weight and compact, best for EDC use.
● Made of aircraft-grade aluminum alloy, premium type Ⅲ hard-anodized anti-abrasive finish, toughened and wear-resistant.
● IP68 rated dust-proof and waterproof, submersible to 2 meters.
Applying the coupon code "LMTAA2" on GearVita, only $18.99 needed, you can get this best-selling mini AA flashlight: https://gearvita.com/lumintop-tool-aa-2-0-flashlight-650-lumens.html
Related products:
lumintop odf30c
lumintop gt mini
