that's awesome - and means someone smarter than I am might be able to figure out how to disable the protection.
any idea what kind of output (watts) you were getting?
I Estimate around 22 Watts. I took apart the light to do this and get the Vf and I. :bigsmile:
wow, that's great - I hope someone will figure out how to permanently bypass the protection - though it is kind of big to fit in single cell lights...
edit - wait...so you were measuring output too LEDs and not input to driver? did you measure input, too? because if it has decent efficiency w/ one cell.....even better! thanks!
Wow! nice work!
@dthrckt: Wait, I think I'm lost.. Yes, I was measuring output to LEDs with 2 cells. Measuring input wattage to the driver? Hmm, that would be batteries voltage (under load) x tailcap current = 7.78 x 3.75 = 29-30 Watts?
Calculating for efficiency using Vbatt x Ibatt x Efficiency = Vf x If
Efficiency = (Vf x If) / (Vbatt x Ibatt)
Efficiency= (9.2 x 2.4) / (7.78 x 3.75) x 100 = 75.68% efficient
Not calculating other losses such as internal resistance on the switch and tail cap.
@atbglenn: Thank you!
that's what I meant (output, input, efficiency)
but i thought you were getting 22 watts to emitters with ONE cell :) which is why i was pretty excited lol
anyway, 75% beats the pants off the last driver I tested efficiency on
Ahah, sorry about that. The driver could be around 80% efficient if you factor out the resistance from the tail cap, switch, wires.
if you don't mind I'll fwd a link for this thread to ian mander. he maintains this driver db http://www.videofoundry.co.nz/ianman/laboratory/research/driverlist.php
so, would you say (at least visually) you get decent output w/ the single cell?
I don't mind! I say there is a bit of decreased output with only 1 cell, but it does work. It draws about 2A on a single cell.
ok, i'll email him.
thanks, for the info.
@dthrckt: Apparently you can just ask Kaidomain and they'll send you one without the low voltage protection - http://kaidomain.com/product/browsediscussions/111
@jufran88: Great build, thanx for sharing! Is it possible you can perhaps test the light with 2 x 18650's and let us know if they can supply the same level of amps than the 2 x 26650's. Also, which Ledil Boom reflector did you use (S/M/W) and where did you get them from?
I will probably try that! thanks for letting me know.
and yes, thanks again jufran for sharing.
if you want a tighter spot, the Ledil Reginas work well with XM-Ls, you just have to hand ream out the hole to 7-7.5mm first. I've never actually used a Boom SS (although I have one in my bits box) but I've used Reginas a lot. I personally don't much like the bright spot/dimmer spill of reflectors, so I've moved over almost entirely to TIR optics for my bike lights (different requirements though), but the Regina is one of the best throwing 20mm reflectors for XM-L.
oh, great build too BTW :)
Nice clean build, thanks for posting this.
Wow, really nice buid!
A question, though, can you edit your original post and include the links for reflectors and lens (and any other parts sourced from the net)?
More pics of the pill and the assembly would be nice too. ;)
Thanks for the post!
Viktor
Sorry guys for the late responses. I been away and just got home from work. I have gotten some outdoor shots when me and my girlfriend went up Mt. Hamilton for a drive. I also got some outdoor shots of my DRY. I'll post a comparison later.
Here they are!!
High (Sorry this was the first shot I took and didn't notice it was blurry)
Med
Low
@Lothar: I'll try it! I'll post up some info when I get the chance to do it! I used the Boom MC-E spot reflectors. The OP has been updated with the link! :beer:
@mattthemuppet: Ooh, I might try that. It seems its a bit longer than the Boom reflectors, so maybe I need to trim the inside so the heat sink can sit lower. I noticed with these boom reflectors that there is some light escaping the bottom so I'm losing a little bit of output there.
@Old-Lumens: Thank you!
@viktori: I will update it!
Wow! Very nice!
@fishinfool: thanks!!
I forgot to add this picture
It just started sprinkling when I started taking these pictures.
This is an awesome build.
jealousFoy
thanks foy! :)
