Just placed my order as per instructions.Now waiting for the price adjustment.This is my first GB in BLF or any other forums.I am sure all the hard work you guys are put in here will “shine” out very well.As of my order 29/31 left
Just arrived home after work, and I found a nice surprise at the doormat, a little package from Sofirn ;-)
The production models include the same fragile pocket clip as the prototype models.
Please be careful when removing the clip in order not to break it. In my flashlight drawer I found another clip (I do not remember from which AAA flashlight, which is much more robust); Sofirn production pocket clip on the right.
The Sofirn manual states 35 hours runtime with an Alkaline battery. This weekend I measured the following runtime with brand new IKEA Alkalisk alkaline batteries: 4500K PROTOTYPE model 33 hours, and 3200K PROTOTYPE model 34 hours runtime.
Really funny by the way how you can "lego" Sofirn C01 and Fenix E01. This is the way to go if you want to add a magnet or a tritium vial to your Fenix E01 ;-)
Finally, I noticed a difference with the production model versus the prototype model: my 5600K production run C01 had a slightly bright hotspot at the center, which the prototype model had not. The 3200K production was evenly floody. I am not sure if this has slight hotspot has to do with alignment differences of the LED in the reflector during production.
I am super happy with the Sofirn C01 as new member of my 5mm LED flashlight family :-)
This weekend I did a little runtime test with some 1AAA 5mm flashlights running them on IKEA Alkalisk batteries(1.79 Euro for 10).
Results as following from LED on to completely dark:
1. Varta/Rayovac Indestructable 1AAA: 43 hours (of which the last 36 hours really dim)
2. Sofirn C01 3200K (PROTOTYPE): 34 hours (approx. 20 hours of regulated output)
3. Sofirn C01 5600K (PROTOTYPE): 33 hours
4. Fenix E01: 26.5 hours
5. GP Discovery CLE202: 24 hours
6. Gerber Infinity Ultra task light: 7:15 hours (much lower than expected)
0. Control: Zebralight H53Fc on AAA alkaline: 45 hours on 3.5 lumen (lowest M). After that 5 more hours on highest Low. Then it started to flicker. When removed battery measured 0.85 Volts. Still good enough to light a Sofirn C01.
Edit 1: added prototype clarification
Edit 2: added Zebralight result
I noticed exactly the same with my 5600K vs 3200K. If you are looking at the photophor die area, the one of the 5600K seems smaller and better defined as the one of the 3200K. Don’t know if there is a die area difference with same dome or a dome difference with same die area between them. Anyway, I really don’t care.
Somewhere earlier djozz mentioned that there were differences between the Yuji LEDs. I noticed this as well.
Left is the protoype C01; middle and right are two production run C01s from the same batch; the one on the left and right are more "rosy"; the one in the middle is more "yellow".
Still I like both better than my Zebralight H53Fc (high-CRI, 4000K, however with green tint). I guess I lost the Zebralight tint lottery :-(
Please bear in mind that these tints somehow look much more dramatic in this picture than in real life.
When using outside in real life even the Zebralight is actually quite good.
My GIU was recently ordered on Amazon.com. My goal was to experience this light as an AA form factor for a 5 mm flashlight, as according to Parametrek the GIU is the ultimate host for a Yuji LED. Perhaps my particular GIU is malfunctioning, or perhaps Gerber changed something to its driver recently in production, who knows?
The cause for the low runtime was not the IKEA AAA Alkalisk battery. After the GIU went dark, I transplanted the AAA alkaline battery into a Fenix E01 which run for 17:30 hours on moonlight. In the future I will try to repeat this test with the GIU, but first I have to acquire some new alkaleaks. Usually I only use NiMH cells.
Although I am disappointed by the low runtime of the GIU, I do like the sturdiness of the form factor, and the option to run both AAA (without adapter) as well as AA cells in this light. Perhaps it is possible to do some surgery on it and transplant a Sofirn C01 driver into it
Except in TV-remotes we don’t have many AAA batteries in our household, but we do have lots of AA’s.
Because the missus put new ones in her electric toothbrush as soon as she thinks the thing misses a beat.
The old batteries go into “the drawer”. That has almost the hallmarks of creating a new ecosystem.
I would feel safer if we could put the more virulent ones down after they were totally drained.
Edit: and with an AAA to AA adapter you would have your own Gerbivore for a fraction of the price.
I was also considering putting these emitters in my two Gerber Infinity U’s. Love that light. Carried one everywhere whien I was in the army. Lost at least two of them somewhere around the globe.
But with that runtime, I’m not sure it’s worth it.
I sent Sofirn a message asking if they have a target date for availability of the red/blue version of the C01.
If/when I receive an answer, I will update.
I received the two 3200K C01’s that I ordered today. Nice little lights, both 5 lumen flood, both 97CRI but one slightly rosier than the other.
The differences from the prototypes from what I can see sofar:
*unlike what slowtechstef mentioned, the clip is a bit different from the prototypes, less stiff, fits better around the light and is easier to remove and click into the groove again, I use a small screwdriver like this:
*the leds seem just a littlebit more protruded
*a magnet is perfect fit now but does not clamp, you need glue to fix one.
*the trit hole seems a bit smaller,(it was too large in the prototypes), but I can’t compare because Stef still has my prototypes.
*the switching on feels more firm than in the prototypes (circuitboard sits better in place)
*I have not opened up the driver/led cavity yet so have not checked the potting.
The C01 will have to proof itself over time but the signs are good sofar: we got all that the Fenix E01 already had, plus the Yuji leds, reversable clip, tailstanding, included splitring from which it hangs straight down, and a space for a magnet and tritium vial, for a better price.
And I think it looks better
“Reason: System error.
Suggestion: The system is busy. Please try again. ” And was told to try again later, but always the same…
So I re-ordered (this time one of each) and didn’t wait for discount, and the payment went through on PayPal right away… so at least I’ll getting mine sometime.
Thanks BLF —- I think I’m going to like this light.
