y first EDC flashlight that has an electronic side switch. All of my other EDC lights are and have been twist operated lights.
This is also the first EDC light that I own that has magnetic charging, this is a great feature. Now I don't have to take out the battery every time to charge it then put it back in.The Fenix E18R comes with a Lanyard, Magnetic Charging Cable, Key Ring, Spare O-Ring, and a printed out user manual and warranty card.
You can also download the user manual like I did on the Fenix web site. It is in a PDF file.
The E18R is a great flashlight! It is using the Cree XP-L HI LED. It is small, very bright, well made and in Turbo mode with the 16340 3.7V Li-ion rechargeable battery it is extremely bright!
The flashlight is small and light (33 grams) for an everyday carry flashlight, if you have extra large hands like I do then it will "just fit" in your hand without being too small to hold.
The finish on it looks excellent. It is made from premium type 3 hard-anodized anti-abrasive finish.
The flashlight is made of aircraft-grade aluminum.
The threads are nice and smooth.
The light has reverse polarity protection so you can't install the battery incorrectly and burn out the circuit. They look like two half moons located
in the head where the positive battery contact is for the battery.
The light also has over-heat protection and has digitally regulated output to maintain constant brightness.
Charging time with the included ARB-L16-700P Li-ion Battery is about 80 minutes.
The flashlight can stand on a flat surface to act as a candle.
The light gets warm fast in turbo mode, in 10-15 seconds the light will get warm. In two minutes the light was not hot yet and still can be held comfortably. After some time in turbo mode the light will get hot. I ran it for 17 minutes, it could still be held but not comfortably at all due too the high heat. This is to be expected in a small light with a very high output.
Magnetic Charging
The magnetic charging cable should have been longer. If you are plugging it into a wall socket with and USB charger and want to put the light on a desk like me, then the magnetic charging cable won't be long enough.
The magnetic charging cable is long enough if you plug it into a wall socket with a USB charger and set the light on the floor.
It is also long enough if you have a desktop computer on the floor or table, then just plug the cable into a USB port and set the light on the table.
The cable is also long enough if you have a laptop that you will be charging the light from.
The magnetic charging cable has two LED lights in it. The orange/red LED color = charging, the green LED color = charging complete
You can use the light while it is charging but the charging time will be prolonged. I tried using the light while it was charging and it worked fine.
From the review that I have read the magnetic charging cable and magnetic port are not compatible with Fenix's other magnetic charging cables and magnetic ports.
One example is the Fenix RC11 magnetic charging cable can not be used on the Fenix E18R, and visa versa.
Update: 12/14/2018 - I just found out that Fenix does have a magnetic charging cable that will work for the RC05, RC09, RC11 and E18R.
Spare USB cable with magnetic connection plus MICRO USB connection, SKU: FX-MAGUSB. MSRP: $7.00
Battery
The flashlight can be used with a 16340 Li-ion rechargeable battery or a standard CR123A 3.0V battery in emergency.
You will not get the ultra bright Turbo Mode (750 Lumens) using a standard CR123A 3.0V battery, it needs a 16340 Li-ion rechargeable battery to get the ultra high 750 Lumens.
You will probably get 350 lumens max with the CR123A battery. The Low-voltage warning feature will not work either using a CR123A battery.
The ARB-L16-700P battery that came with my flashlight had a charge of 3.65 volts. You will need to fully charge the battery before you use it. Turbo mode not work with the battery charge of 3.65 volts.
When the battery is fully charged and the voltage drops to 3.70 volts, turbo mode will no longer work, when you select turbo mode it will flash one time then drop to high mode. This is due to the battery not having enough voltage to run in turbo mode. Also the Battery level indication LED will be Red constant on: poor (50% - 25 %).
The flashlight has a Low Voltage Warning when the battery voltage drops low. It will downshift to a lower brightness level and the battery level indicator blinks red to remind you to recharge the battery.
The light also has an electronic Lock/Unlock feature.
The flashlight will operate for a limited amount time in Turbo mode at 750 lumens, then it will slowly and gradually downshift to a lower brightness until it reaches about 350 lumens, at that time it will hold the brightness until the battery gets too low.
The downshift from 750 lumens to 350 lumens is slow and very smooth. I tried to show this in my video below.
When you first get your light you will have to remove the round black insulation sheet from the battery for the first use.
A note about the included ARB-L16-700P Li-ion Battery. It is not listed on the Fenix web site or anywhere else.
Fenix told me that the ARB-L16-700P is a newer version battery released about one month ago.
The ARB-L16-700P battery has a 1/2 more amp output than the ARB-L16-700 battery. Either battery will work well in the E18R.
I have tried my ARB-L16-700 battery in my E18R and it worked great. The ARB-L16-700P just has an extra 1/2 amp out probably for turbo mode.
I don't know if Fenix will be releasing the ARB-L16-700P Li-ion Battery. I was told and also the E18R user manual says you can use the ARB-L16-700U or ARB-L16-700UP batteries.
The E18R can use the following batteries:
- ARB-L16-700 - Rated at 2.59Wh
- ARB-L16-700P - Rated at 2.52Wh
- ARB-L16-700U
- ARB-L16-700UP
- CR123A 3.0V battery in emergency
On/Off and Output Selection
To turn on the light press and hold the side switch for 0.5 seconds. The light will come on at the default low mode setting. Press the side switch one time each to cycle thought the other modes.
To turn off the light in any mode that it is in press and hold the side switch for 0.5 seconds.
The modes are Low, Mid, High, Turbo. For Strobe mode press and hold the side switch for 1.2 seconds in any mode. To exit Strobe mode press the side switch.
If you have the electronic lockout mode activated, to turn on the light double click the side switch two times in 0.5 seconds. To turn off the light in any mode that it is in press and hold the side switch for 0.5 seconds.
The light does not have mode memory, it will not memorize the last mode that you were using and come back to it when you turn the light back on. This would have been a nice feature to have. So every time you turn on the light it will default to low mode and you will have to cycle though the modes.
Electronic Lockout Function
Lock: With the light unlocked, press the side switch twice within 0.5s. The light will blink twice on Med to indicate locked status.
Unlock: With the light locked, press the side switch twice within 0.5s. The light will be unlocked and activated on Low.
In locked status, clicking or pressing the switches will activate 2 one-second blinks to indicate locked status.
Battery Level Indication
With the light switched off, single click the switch to check the battery status. The battery level indicator will display the battery status for 3 seconds.
Green constant on: saturated (100% โ 85%)
Green flashes: sufficient (85% โ 50%)
Red constant on: poor (50% โ 25%)
Red flashes: critical (25% โ 1%)
Lumens and Runtimes - Using the Fenix Rechargeable 16340 Li-ion 3.7V 700mAh Battery
- Low Mode = 5 Lumens - 70 Hours
- Med Mode = 30 Lumens - 13 Hours 50 Minutes
- High Mode = 150 Lumens - 2 Hours 35 Minutes
- Turbo Mode = 750 Lumens - 45 Minutes
- Strobe Mode = 750 Lumens
Low-voltage Warning
When the voltage level drops below the preset level, the flashlight is programmed to downshift to a lower brightness level until Low output is reached. When this happens in Low output mode, the battery level indicator blinks red to remind you to recharge the battery. To ensure normal use, the flashlight will not turn off automatically and will work till the battery level runs out.
Note: This only works with 16340 Li-ion battery.
Time-limited Downshift
The light will accumulate a lot of heat when used on High output level for extended periods. When the light has been used on Turbo for a certain time, the light will automatically step down by a few lumens to reduce the temperature. Turbo mode can be reselected.
Pros:
- Small size, very bright, well made
- Magnetic charging
- Can be used with a 16340 Li-ion rechargeable battery or a standard CR123A 3.0V battery in emergency
- Low Voltage Warning when the battery voltage drops low (only works with the 16340 Li-ion rechargeable battery)
- Battery level indication
- Lockout function and multiple ways to avoid accidental activation
- Can stand on a flat surface to act as a candle
- Magnetic tail
Cons:
- No memory, the light will not remember the last mode that it was in when you turn the light back on
- The magnetic charging cable needs to be longer
- The charging connection and side switch can get confusing, it's easy to press the charging connection instead of the side switch
Specifications:
- Cree XP-L HI LED
- LED lifespan of 50,000 hours
- Max output of 750 lumens
- Beam distance of 446ft (136m)
- Powered by one ARB-L16-700P power Li-ion battery, or CR123A Lithium battery in emergency
- Reverse polarity protection to protect from improper battery installation
- Digitally regulated output - maintains constant brightness
- Magnetic charging in the neck, specialized magnetic charging cable and one included ARB-L16-700P power Li-ion battery
- Magnetic tail
- Side switch for one-switch control
- Intelligent overheat protection
- Low-voltage warning reminds when battery charging is needed
- Premium type HAIII hard-anodized anti-abrasive finish
- Made of durable high-strength and oxidation-resistance aluminum
- Automobile optical lens coating process
- IP68 -Rated: totally protected against dust and foreign objects and submersible to 6.5 feet for 30 minutes
- Length: 2.4โ (60mm)
- Diameter: 0.8โ (20mm)
- Head: 0.8โ (21mm)
- Weight: 1.17 oz. (33.3g) excluding battery
Accessories Included:
- 1 x ARB-L16-700P Li-ion Battery
- 1 x Lanyard
- 1 x Magnetic Charging Cable
- 1 x Key Ring
- 1 x Spare O-Ring
- User Manual
- Warranty Card
- Information Leaflet
Edit: All pictures were deleted. Photobucket wanted the pictures removed or pay a monthly fee to host them.
When I posted the pictures years ago it was free, no monthly fee to host them.
www.youtube.com/embed/XLjTC2-oG_s
www.youtube.com/embed/dQ8k-AUylow
