Known as SC07. Good for soldering aluminum. High melting point, but very strong joint. I have 250gr 0,7mm spool lying unused. Bought for it’s “slightly” better thermal conductivity but the higher melting point made it my last choice.
If you don’t plan to remove the LED later, then we can easily braze the chip directly to almost any metal. The brazing material can be anything with melting temp lower than 1500°C. Copper or Silver is a good candidate.
Can someone explain how to wet aluminium with Sn99.3Cu0.7? Tried to do it over heatsink material in the past, to no avail. I can understand it has to do with the particular aluminium alloy of the heatsink, maybe some 6061 crap, and insufficient surface sanding down. Hello?
I’ll post a pic and video for you guys. But, I have to modify my hot plate (cloth iron) to 260ºC first. It’s only maxed at 210ºC. Rarely use lead free solder these days.
Tried to wet large area with SC07 and 60/40 at 260ºC max. and the result was not successful. I could only wet no larger than 3mm diameter blob. With 60/40 the blob was larger and easier but 5mm was the largest I could get. I had successful result but that was using my stove hot plate at 320ºC which I no longer have. Already converted the stove hot plate to a clamping fixture on my mini milling machine.
FYI, soldering aluminum with Sn based solder is not reliable, unless there’s a continuous voltage in the junction to feed the galvanic difference. Adding Zn in the solder will last longer. I don’t recommend soldering aluminum directly in everything elsa but mechanical or structural projects. Most aluminum fluxes requires high temperature to properly activated (300ish ºC). The most successful way to solder aluminum in electronics is to first plate the aluminum with nickel - gold or copper.
Plating aluminium with copper but what kind of aluminium we're speaking of here? The aluminium used to craft heatsinks or flashlights can be some sort of suckass aluminium alloy which won't plate easily, so I hear you better first zinc plate it then copper plate or something like that.
I’ve really come to like the stuff, it makes reflows much less stressful especially with larger MCPCBs. You’re nowhere near the point where the emitters start to degrade and PCBs delaminate so you can take your time.
It also helps a lot with soldering wires where a large thermal mass sucks heat away quickly, which sometimes is unavoidable.
Only for leads, never use for this Sn42Bi58 for attaching LED. It has very bad thermal conductivity, approaching that of stainless steel. Somewhere around 16 W/MK. I usually mix some with Sn60/Pb40 to make melting point slightly higher. 138°C is too low
540W/MK is outstanding! So does the price I guess. Its so hard that only EDM machinable which is very slow. I machine a 2mm, 45mm deep oil passage in a hardened race bike’s crankshaft few years ago. Precise control and diameter tolerance was an issue.
The first one that I found would do 400 PCBs (that’s their MoQ) for mere $14K.
Maybe others are cheaper…anyway it shouldn’t hurt our record-chasers to ask for samples.
