Imalent HR70 DOA - trashed it
Imalent RT70 worked for a week than died - trashed it.
No more Imalent for me
my imalent dx80 died on me…
suddenly flickered and died
bought it in january this year
emailed them a week ago… still no reply…
gearbest only offer usd 30 for refund…
not helping either…
beffore this im using dn70 and hr70
both of the light working fine
seem like their multi emitter light is not be trusted…
too many issue
Good grief… So sorry man….
I consider Imalent not the most reliable brand, but I do feel they have the X-factor that makes me want their lights. I bought two DT35 and two DT70 lights dirt cheap. Both work without problems.
I must be extra lucky, as my DX80, DN35 and even the old DDT40 all still work fine. Granted I’ve not left the DX80 on turbo more than a few minutes at a time, understanding the thermal issues since it has no fan.
KuoH
DN35/DN70.
Both fine, once you modify the touch surface of switches to give more “feel” in the dark.
My walkabout lamps most times when I only taking one.
Just be gentle with cover over charger socket.
it’s easy to remove. AND replace.
Well made, feeling lamp in my eyes.
Hi SSS,
Sorry to hear about your DX80. I’ve seen others with DX80 issues and sometimes it looked to components on the BMS that fried.
Do you still have battery voltage on the output to the head? Curious if its the same issue since you say it flickered.
nothing…
no display, cannot be charge…
and strong smell of electronic burning
the battery pack read 15v on my multimeter…
i guess the battery pack is still good
probably fried the main board…
does TA driver compatible with dx80…?
maybe will mod this light using blf gt carrier
and replacement driver
If it cant be charged, I wonder if it is the BMS then. Maybe the BMS can still output correct voltage after frying, but will not output more than a few mA? So multimeter will work but nothing on the light will… Could be the transistors on the BMS (they are very sensitive, especially if they are fakes). Just some things to check if you are interested.
If only it was a TA or Lexel design. It would have been worth every penny for Imalent.
I think the hardest part is getting inside the head to replace anything. Opening the battery looks much easier.
Here is a similar situation to yours maybe: REVIEW IMALENT DX80 COMPLETE. - #427 by Wieselflinkpro
hopefully…
now i got massive samsung 30q + xhp 70.2 paperweight sitting on the shelf
got to do some thing with it…
and no more light from imalent for me…
their warranty is non-existent
I have only an Imalent HR20 headlamp.
The headlamp itself is still working after light to moderate usage since 18 months, but the headband is crude, cannot keep the headlamp in position.
Output level adjusting screw is somewhat wobbly, and needs readjustment moderately often, when I want to change output level.
Did not try its water resistance, and won’t (as I read here on BLF, that somebody had this model failed even under basic water resistance testing conditions).
Imalent R90C is a very tempting flashlight based on the specifications, but I won’t risk to pay for it (even with discounts), if there is considerable chance, that it will fail soon.
I had two of them, both with serious problems. After a long discussion they had been replaced.
-HR20, a screw inside the Head was missing, the other was loos. So after 3 days the switch and output level adjuster starts hardly wiggling . .
-DN12, something wrong with the driver. The moment i turned it on, i got an heat alarm and the light reduced power.
Do i get the poll right?!? 45% (with problems) vs. 35% (with out problems)
This would mean 56% of all Imalent lights have serious quality problem?
Sorry, but my decision is clear - Imalent, never again.
Yeah… Unfortunately
being someone who worked in an outdoor shop and had a short contract with imalent on a few shipments, the older Imalent tends to have more issues, otherwise the latest one not so much
The DX80 I won has been working flawlessly since I got it.
That said knowing their rep if I was in the market to buy I would really second guess them.
I missed Imalent LCD and dual buttons and USB port.
Their DT35 is very nice light though lower output than spec.
Never had a problem with my 5 Imalent lights.
I’ve had Acebeam and Olight issues though amongst many other brands.
I’ve had over 100 lights in less than 3 years and I bet 15-20 had faults.
Been very happily using an Imalent DN70 as my EDC for nearly a year. No problems at all, except the well known difficulty of finding the switch in the dark. I solved this by adding a lump of white adhesive rubber under the switch, makes it visually easy to see the switch, even in dim light, and easy to feel for it in the dark.
Hello, SSS,
Sorry but we didn’t get your email till now. Usually we answer all emails within 48 hours, and if you didn’t get an answer, means we didn’t get your email. You are welcome to add my skype: Imalent_shellen, whatapp or wechat +8618926004450, we are sure to give you a solution on your flashlight.
Best regards,
Shellen
Imalent
Hi Imalent! Nice to see you here!
Hello, Everyone,
If anyone has imalent flashlight with problems, can contact us by email sales@imalent.com, skype: imalent_shellen, whatsapp, wechat, cell phone: +8618926004450. I will try my best to solve your problems. We don’t come to BLF or CPF every day, but if you contact me directly, I will give you a solution unless I didn’t get your email or message.
We do value all your kind advice and we are trying our best to improve all the time. We also take our responsibility for any imalent flashlight.
We have done a lot of improvement but we know we still have a long way to go. We will improve day by day.
We do appreciate all your guys’ support.
Best regards,
Shellen
Imalent team
