So, now, some capacity tests!
Iām using my own battery holder with my own large Beryllium Copper spring, which allows accurate capacity testing up to 3A without a 4 wire method.
-I first started testing the NCR18650GA at 2A current, with a charge voltage of 4,185V and ending voltage of 2,6V.
Capacity at 2,6V, being 3308mAh.
Energy at 2,6V, being 11,56Wh.
Capacity at 2,8V to compare with HKJ.
Nothing checks out, so I can confidently say NCR18650GAs from the Aliya Battery Store are legit
-For the Samsung 30Q, it has been tested at 3A, with an ending voltage of 2,6V and charge voltage of 4,191V.
Capacity at 2,6V, being 2963mAh.
Energy at 2,6V, being 10,28Wh.
Capacity at 2,8V, being 2865mAh.
Energy at 2,8V, being 10,05Wh.
With the tests in mind, I can confidently say that the Samsung 30Q from Aliya Battery Store is legitimate
To end on a final note, my results are quite precise, with good accuracy, but on each of the tests, I did not account for the voltage drop of 0,05V during the tests because of the XT60 connectors and wiring, which may slightly have affected energy tests due to lower overall voltage on discharge.
Therefore, all batteries from the Aliya Battery Store, as of December 2018, are all considered legitimate, can be ordered from the link below:
https://www.aliexpress.com/store/1382210
