Ive been looking for a while now for what I would consider the perfect “smaller” EDC style light and seeing how the FW3A is nearing production I wanted to bring this up as an idea. The FW3A is a near “perfect” 18650 EDC, but we dont have anything smaller or lower profile.
I have not found yet a light that:
Deep carry clip
14500 powered
AL 6061 or 7075
20mm or less bezel
Simple knurling
Decent sized thermal shelf or copper pill
FET+1 with thermal regulation (Defined mode sets, moon, and battcheck)
Single emitter (XP-L HI, 219C, LH351D or similar) with OP reflector
Reverse clicky
Ive seen a handful of people talking about wanting something like this, but a thread to discuss might be worthwhile to gauge interest.
I don’t know about the Tool AA V2.0, but the 1st version hanged the 14500 well, except for the heat! It is too thin, the pill is aluminium and so it gets hot very easily.
To nick, if you mod, I would suggest modding a flashlight like the Convoy T2, the Jaxman E3 or the Sofirn SF14! All easily moddable and all take 17mm drivers!
Turned out very nice , It doesn’t get as many lumens as the A6, because of 14500 battery , heat stuff ,and I haven’t bypassed springs etc , but it is still good for its size , maybe 1000 lumens and a nice beam pattern.
Particularly like the XPL Hi , in this kind of reflector , nice spot with an even spill , Also throws better than an XPL A6 ,with a narrower beam, in the SF10 host.
I wac actually looking at modding an SF10, I didnt know if there was a ton of interest for something more mass produced. So far its not looking that way.
Solarforce used to sell a deep carry clip that fit just fine under the bezel of the BLF X5 light, so it sits in a pocket with just the lens showing.
But, alas, Solarforce quit selling it.
This guy was promising but he disappeared
Something about good clips seems to be dangerous, they make people and products disappear
I use the SF10 with a BLF X5/6 Driver and Efest IMR battery and it handles heat better than the Tool AA and eventually better than the SF14 (V1.0)! The thicker body is quite nice to push it harder on output
Thats interesting to hear. I was reading a few other 14500 build threads and a few noted that even using a standard AA it was a really tight fit on the SF10. Id like to take a whack at modding a T10 2014 but considering I can only get them from overseas that would be a lengthy process if I messed up. Currently reading about the SF14
I don’t know why there is no such light on the market, but I would buy something similar if a BLF project would emerge.
I almost lost it a couple of times. Would be great to have one off the shelf to replace it.
Only thing I might change nowadays is switch to another LED. XP-L2 U6 90 cri for instance or Luxeon. And it would be perfect if it could accept regular AA’s as a backup.
