It’s sad to say, but I don’t have any new build plans for a Cree emitter (s). The last was a triple 50.2 and before that a quad 70.2. Just toys and shelf queens. IMHO, ~80cri NW HI emitters from them are the only things I might buy more of anytime soon for gift lights.
The present and near-future of my interests are practical builds. For me, that’s hiCRI arrays running sustainable currents in mule headlamps or Carlo tube lights and pocket throwers utilizing Black Flats. If these turn out as expected and help resolve the pencil beam issue of the BFs then paint me happy! Hoping to see these soon!
It shows the internal structure of the LED and that one (obviously) shouldn't use non-dtp pcbs.
Also, I found some precise values regarding the luminance (these are stated in the product filter/selector):
At 6A and 1670 lumen the LED gives off 553cd which means the luminance is 278cd/mm2 (just divide by the die size - 1,9875mm2). 1670lm is at the center of the possible brightness range of the possible bins when the LED is being driven at 6A.
The luminance based on the lumens: 0,167cd/mm2 per lumen (scales linearily, just multiply with any lumens value to get the luminance at that specific brightness)
I’m not really good in this. Does this imply that the Boost HX has 2.7 times the luminance of even the KW CSLNM1-TG ? (based on the numbers you just posted in the KW… thread)
(edit: maybe the drive currents can not directly be compared)
278 cd/mm² at 83 lm/W? If yes - that’s incredibly good.
At this efficiency HWQP, Q8WP, XHP35 HI do a bit less than 150 cd/mm². XP-G2 is probably slightly behind. NM1 is nearing 200.
No. According to that thread KW CSLNM1-TG does 281.7 cd/mm² when driven to 900 lm.
Boost HX at 6A (which is not peak) does 278 cd/mm². According to the datasheet, that’s 340+ cd/mm² at 8A. And the output curve looks like it’s far from the peak.
Frankly, I find it a bit too good….
Added:
A 1.9875mm² Lambertian emitter driven to 1670 lm has 267.46 cd/mm². Or 160.1 cd/mm²/lm.
The point here is that you can use my conversion factors to calculate the luminance of these LEDs ( I also posted numbers in the other Ostam “white” thread) based on the lumens they put out. Just multiply the two values. You have already measured the lumens at different currents. Now we can calculate the performance of different lights using these LEDs.
There has always been a slight discrepancy between the measured values and using the lumens/(area*pi) formula.
I see that The Diver listed the die size as just 1.25*1.59 rectangle. This is marginally untrue because of rounded edges.
If I calculate size from 0.167 cd/mm²/lm I get 1.906047 mm². 4.1% less? Rounding seems smaller than that, so we have some discrepancy, but marginally smaller than before.
From the application note:
“additional care should be taken to minimize mechanical stress on the silicone encapsulation”. Silicone? I thought they use sintered phosphors. Does that include silicone? Or did they just copy and paste this sentence from another document?
If Boost HX actually becomes available reasonably soon and performs in line with the expectations, it’s going to give LEPs a run for their money.
It’s not as intense, but close enough to compete with the current generation of LEP flashlights. Output is way higher. Efficacy is good. Price…way way lower.
Well yes and know. Those LEDs also have silicone inside the phosphor and it’s not sintered (Cree has never mentioned this as far as I know). I mentioned the article regarding sintered phosphor here.
I’m pretty sure it’s not a premolded part since it encapsulates the bond wires (see the OSRAM document somewhere above). It’s very likely molded around the mounted die.
They talk about the types of materials used here: Link
I know it’s not very “silicone-like” but that’s based on the “typical” silicones we know. Even cheap Fujik is quite different (hard and almost brittle).
The white stuff shows no flexibility at all, it breaks, and makes a scratching noise when I rub it with my forceps. It has at least the hardness of bakelite, or maybe it is ceramic.
I know, the CSLNM1 I have here are packaged in the same stuff. Again, I see no reason why this couldn’t be a filled silicone compound. It behaves like one under the tip of a soldering iron too (gets crumbly around 300°C, never melts). And the advantages in this application are obvious.
How could they cast ceramic around the die + phosphor + bond wires (nicely visible in your pic btw)? They clearly mold this in place.
Aaaaanyway… my point was that there’s fragile bond wires embedded in there and that may be why they mention not to put pressure on it.
