djozz, I just noticed something about your test. You tested the XP-G2 S4 2B with dome on. De-Domed it only goes to 1100lm according to koef3’s test. You numbers of the new Osram are very close to his of the Q8WP, both LEDs are much better than the XP-G2 de-domed.
6.5A seems to be about the sweet spot for the KW CSLPM1-TG (white2 as vinh calls it). I wouldn’t go above that when driving it with a buck driver inside a light that heats up.
I did comment under the graph that the XP-G2 S4 2B test was tested with dome on, and also included that the PM1 clearly outperforms the dedomed version that puts out 10% less.
It is confusing, Osram doesn’t have good names for them.
We basically have a 1mm^2 white flat, 2mm^2 white flat, and the boost HX which is just a bigger version of the 2mm^2 white flat.
I really don’t know how I am getting 400 plus kcd in Brinyte B158? Magic? Bad lux meter which usually under reads dedomed XP-G2 S4 2B with greenish tint (confirmed by you) is possible reason since white flat 1mm is more blueish?
So if B158 goes from 330kcd(g2) to 430kcd(WF1mm) so that is 30%? Yesterday I sold one with same numbers… Same applies for Mitko Super thrower(430kcd! )…
Looks brighter. Throws further in a night…? Strange indeed…
So I put a 2mm² version in my Amutorch JM70.
I don’t trust my intensity numbers, but at 5m my “ceilingbounce” app says :
Before (XP-L HI) : 270kCd
After (CSLPM1.TG) : 555kCD ?!
Same distance, same phone, same all except for the LED… awesome !
I also put a 1mm² in my Cometa :
Before (FET driver + XP-L HI) 200 kCd
After (2,8A 8*7135 Biscotti driver + CSLNM1.TG) : 280kCd
EDIT : My B158B now rocks an 1mm² one too, and a 2,8A Biscotti driver : 345kCd !
High current is not required to get some serious throw with this LED
I don’t know what luxmeter you use but your results are somewhat closer to mine first redneck test(you even got slightly higher results than myself)…
For me B158 goes 430kcd with 5.5 5.8A current draw and when it falls somewhere at 3A(fet driver) it is equalized in performance with de domed G2 s4 2b(driven at 4.7A I have 330kcd in B158 with g2).
For bigger host like SR95S UT of mine that measures to have Vf of 3.28v(I didn’t measure current but should be around 4.5A according to djozz’s graph), BLF GT heat up faster than my mod when I hold them left and right high on my shoulders for ten minutes or so. I think it should be fine for big host to up the current to 5A.
Dang, this thread is long and confusing, unfortunately I don’t have the time to read all posts. I just found the collected voltage vs current and output diagrams in the first post and thought this LEDs could be usable for a 3D printed “kids save” thrower with 3x Eneloop and couple of 7135, perhaps in combination with a 60.0mm Ultra Narrow Catadioptric (10158). Is this a good idea? There are at least 2 similar LEDs mentioned here, which one would be the best choice?
^ yes this is a good led for a low current/power thrower.
But we already had the (dedomed) XP-E2 for that, not many modders have used that led but I have build quite a few nice small throwers with it over the years.
This KW CSLNM1-TG is much more capable though, with its low voltage even with small batteries it reaches its maximum power.
