It may sound strange but why not simply produce v1 lantern body
with USB micro and C port on the same aux board just wired in parallel below one silicone cover
And then in V2 this aux usb board gets replaced with new driver
So the upgrade would only need 3 LED wires soldered and likely a Thermal resistor with 2 wires for precise thermal regulation
It would, but it’d be even nicer to get the lantern out before CNY shuts down China for a month.
Making the hardware theoretically forward-upgradeable might be nice for the handful of people who would bother, but shipping before CNY is something which would benefit everyone. So I would only attempt it if it won’t cause delays.
For the emitters, you might want to consider the Oslon Square 2700k 96CRI. The tint is absolutely gorgeous for the color temperature. No yellow/green. The one sold on Ebay is a slightly rosy 6U tint bin and a high flux bin for the CCT and CRI.
Additionally, E21A 9080 tint mixing would be a really good option.
We may have to consider that option, as we discovered the Samsung 351 series LED are hard to order by the manufacturer. If Olson makes them in both 2700K & 5000K with the same foot print as the 219, XP-L, etc. that would be perfect as long as they are more efficient Lumens-per-watt than the 219 series.
You just need to buy the right tint bin. The 6U is a really nice tint bin. No green at all.
Djozz and DBSAR, if you want, I can mail you a few pieces to test.
You’re right, it’s gone. The link now leads to a similar but inferior product. For the lantern project if interested, Sofirn can contact the Ebay seller or maybe even Oslon directly to see if they can source more of the 6U tint with MQ flux bin.
