Is it too late to up my qty from 1 to 2 lights total? I would like 1 of each led type.
Thanks for everyone’s hard work.
Cpeng 2x lights total (1 of each tint)
As Leo Buscaglia once said,
Those who think they know it all have no way of finding out that they don’t.
I would be more interested in the 219C SM4070E tint bin because the efficiency and output is higher and tint is similar to the 219B 9080 except red rendering is not as good.
Just some thoughts I had.
We have 166x lights signed up now and it might grow to 1800 lights (1500 people) by the time the orders are ready to be put in. If half will be for the xpl-hi, that’s maybe 900 orders total of that. Assuming the production doesn’t hit any snags, Lumintop can probably build those in 2, maybe 3 weeks. (IIRC they did 400 Q8’s per week)
I suppose you could divide the list into 2 batches so roughly 750 people get the PM with order instructions. That might result in 400 orders. Those can get shipped. Then a week or 2 later do the other 750 people.
Then a week or 2 after that the LH351D version will be ready for orders.
If the same coupon code is used, all 1500 or so people signed up will order the LH351D at once resulting in long waiting. If a new code is created for the LH351D then it can be sent in 2 batches like the xpl-hi version.
This might reduce the time from “Payment to Delivery” which some people are sensitive about.
We could have 90% of all orders done over a 6 to 8 week period, fingers crossed.
It would also be wise to ship an early production version to someone close by who is familiar with Anduril to make sure it’s functioning correctly. Luckily Neal shipped a GT to Steel1024 in Taiwan who found an error in the way Narsil was flashed (I think 2 numbers were swapped by accident). Lumintop was able to reflash all the drivers before shipping and prevented a big problem. Maybe Neal can be shown how Anduril is supposed to function so he can check that the production lights work like their supposed to.
Anyway, just a few thoughts I had. I’m sure you guys will find the best way to do it. Cheers.
IIRC Clemence mentioned there was/is an extremely high minimum order requirement to go along with the lottery concern, though I agree the sm4070e to be a great option.
After hearing how the LH351D looks in a TIR triple I absolutely wouldn’t be opposed to another option. When that poll was run the SST-20 wasn’t big like it is now, IDK if those have good tint bins available though.
If we could get 219Cs (or the new LH351C… although its kinda untested) that aren’t super green I’d absolutely be up for that too.
The low spot is the best place to hold it. It works particularly well between two fingers in a cigarette-style grip, sticking out like a second middle finger. If I put it between my middle and ring fingers, I find I can hold it comfortably while also doing other things with both hands, or even holding something else at the same time.
The raised tail section keeps it from slipping, and the button ends up right where it needs to be for a thumb press.
There are also about 400 lights for TLF, so it’s over 2000 already.
About how to handle messages and possible ordering codes and possible delays, not much is decided.
It might be possible to allow only XP-L HI orders at first, and then send messages out again later when the LH351D is ready. Or maybe Neal’s shop could list and allow orders for both, with a note that the LH351D will ship a few weeks later. That makes some things easier, and makes other things worse. Or hold back everything until both are available. I think it mostly depends on which set of headaches Neal is willing to deal with.
I agree that would probably be a good idea. I think that was supposed to be the idea behind proto3, and production was originally supposed to start quite a while ago, but proto3 didn’t result in a lot of useful feedback. So we’re still kind of in limbo.
It’d be nice to get a final sample to test and approve.
Yeah, when the poll happened, the theory was that production would start soon. But then a lot of time passed. It’s probably too late to do another poll, but I definitely wouldn’t mind if more emitter options were available after the initial batches. It might be good to have SST-20 high-CRI options in at least two color temperatures.
… and, personally, I thought the XP-G3 looked fine too. As long as it’s behind a frosted optic like 10511, the rainbow effects go away.
The throwier 10507 optic is popular, but it makes almost every emitter look bad. Meanwhile, the frosted 10511 makes almost every emitter look good, and it can be polished to give more throw if desired.
The overwhelming consensus seems to be doing the xpl-hi now and do the LH351D later once good tints are procured.
I did not comment on it, but I also prefer doing the xpl-hi first.
For sure, TK, it would be great to get a final sample to test and approve. I really hope this can happen somehow. We all know how things can get really messy, really quickly, if there are problems with the initial run. The Miller had the patience of a saint dealing with these issues in one group buy, and I doubt anyone else would want to deal with that. I certainly wouldn’t wish it on anyone. I know there were other factors, but I assume dealing with it all contributed to his burn out of group buys, and this forum.
If we want the very best selected LED SKUs then we have to accept that there is a yield issue.
It’s not as if the manufacturer just twiddles a knob and chooses the tint for that batch.
The concomitant is that once you start cherry-picking the “good” ones, (which itself is costly) the quality of the rest reduces.
If you want only the “best” ones, then that can only be achieved on the back of a much bigger production run. Which requires a market for all the rest. If that isn’t there, then it won’t happen.
Wow, Tom Tom made a really good post. No sarcasm, no insults, no cockiness, no bragging, etc… Plus it was relevant to the subject at hand.
Nice :+1:
And short.
Time is either ticking away (negative thinking) or moving forwards (positivity).
Meanwhile this thing seems to be in limbo. And borderline chaos.
Neal, since you seem to be “the man” here, please get a grip and try to sort things out, and communicate. Don’t bottle it. Again.
If you can’t do such simple stuff (procurement etc.), send TK a proto3, nor set up the distribution chain in advance, well. I’d better say no more.
Not expecting a reply :frowning:
I’ve been thinking about it more. Can we require that TK most preferably, or if not, someone else who will test and report, get a final prototype before we go forward? Is this possible? It might very well save a lot of issues in the long run.
Could anyone be kind enough to give a one sentence summary of where this is at?
Pages and pages of snips and snipes, giant collections of quotes nested 4 deep,…
Moving forward at it’s own pace. :smiley:
“”Current status”:FW3A, a TLF/BLF EDC flashlight - SST-20 available, coupon codes public (2018-11-28): Trying to get production started.”
Yeah, thanks Jon. I can see that on my own.
I was referring to it looks like that team isn’t there any more to update it and it’s all on TK and Neal now.
Won’t ask again.
