I picked up some 60/40 Rosin Flux Core from ACE Hardware today. Made by: Alpha Fry, product # 31605. .032” diameter. Melts at 374F. Its a spool of 4oz. $9.99
So after doing a couple of flashlight driver and led upgrades I had to break down a buy a better iron. My Walmart cheapo iron wasn’t cutting it, it would go from working okay to dead cold, then warm.
I bought a Weller WLC100 and a 5 pack of conical pointed tips from Amazon. It has to be better than what I have been using.
Lead free solder totally sucks.
It refuses to flow nicely, even when you add a lot of flux.
(but maybe you need dedicated flux for lead free solder?)
Melting point is higher too.
I really hate lead free solder.
A small spade bit (shaped like a flat head screw driver, more or less) can be very useful for soldering wires to the LED board.
It has a bigger surface area at the tip, so it will go faster.
You can push down the wire with it too.
But a pointed tip is more versatile.
Sometimes i put on a sharp pointed tip for SMD parts (on drivers for example).
Conical are not very useful due to their small mass and small contact points. If they don’t perform well enough, you might buy some chisel tips. They have larger mass at the tip and can make better contact.
The wire you have has flux inside it. It burns away quickly so you want to feed the solder/flux into the joint. Having extra flux makes everything flow better and gives nicer performance. The videos I posted explain it.
Anyway, something you might try when you get wifi access is to download all the videos from YouTube using www.keepvid.work
I use it all the time to download 720p resolution videos to watch when I’m away from wifi. You get a popup junk page once per video, but it’s no big deal to me.
I’ve been using Kester 44 since the late 60’s. At first, I was using 60/40. Then in the 70’s I switched over SN63 (63/37). SN63 gives a brighter finish than 60/40 from my experience. That being said, I wouldn’t be caught dead using lead-free solder. It sucks big time.
There are different brands and formulations of flux. Like with any type of product, there are companies that try to make it cheaper at the expense of quality. So you want to stick to good brands like MG Chemicals, Kester, SRA, etc… if you want good performance.
The best flux I have ever used Amtech NC-559-V2 Tacky Flux
Went to tractor supply and picked up a few small syringe’s and dispened some into one. Been using that small syringe for months now and you can barely tell I have used any out of the original. If you pull back on the syringe a little after use, then it doesn’t leak once it sets awhile. It also works better if you file down the beveled tip until its flat. Keeps you from sticking yourself too.
