Enogear AA Stainless Steel (AA/14500)
317 posts / 0 new
SKV89
Last seen: 21 min 32 sec ago
Tom E wrote:
I received my Nightwatch IRA from enogear yesterday – site is till down though. The IRA is one big chunk of alum with also a nice chunk of copper press fit, acting as a thick shelf for the MCPCB, which is also copper, anchored with 2 screws. It looks like a modder drilled out the shelf, cut a piece off of copper bar stock, and press fit it in there nicely.
Yep I bought that from them too. That host is impressive. What are you planning to use it for?
From all the 26650 host I’ve seen, this Nightwatch IRA and the Jaxman X1S is the best from a thermal performance standpoint. Should be able to sustain 2k+ lumens easily with an XHP70.2 P2 bin
Tom E
Tom E's picture
Last seen: 52 min 54 sec ago
SKV89 wrote:
Tom E wrote:
I received my Nightwatch IRA from enogear yesterday - site is till down though. The IRA is one big chunk of alum with also a nice chunk of copper press fit, acting as a thick shelf for the MCPCB, which is also copper, anchored with 2 screws. It looks like a modder drilled out the shelf, cut a piece off of copper bar stock, and press fit it in there nicely.
Yep I bought that from them too. That host is impressive. What are you planning to use it for? From all the 26650 host I've seen, this Nightwatch IRA and the Jaxman X1S is the best from a thermal performance standpoint. Should be able to sustain 2k+ lumens easily with an XHP70.2 P2 bin
Well, wish I got the XPL version, not sure if still available anywhere anyway, but for this one, a 351D or XPL2 would under utilize it's heat capability, and the OP reflector is not a good match up. Think'n of XHP70.2 P2, FET+1 driver, and two 26350 cells - should get 6K+ I would think.. Now in stock form, the 2 26350's don't fit. You can actually unscrew the battery tube from the head and still have electrical contact, could add a washer or something, but don't think that's a good setup. I'm think'n replacing the driver spring with a brass button (height is little tricky there) and for the tail, need to get that brass retaining ring lower. Could shave/sand down the plastic washer, then trim off the knob inside the rubber boot. Might pick up a mm or 2 there, combined with a mm or 2 at the head with the brass button, maybe the cells would fit then with all pieces fully threaded in tight.
Ohh for the driver, think it's 32 mm, and best driver would be an L6 LDO one like MtnE sells, and could file it down a bit and piggyback it on -- didn't check/verify all this yet.
duvallite
Last seen: 11 months 1 week ago
My ss 14500 showed up surprisingly today. Still showed as being in LA yesterday. It looks really nice, has the slight gap between head and body, and works fine on an eneloop with a warm, slightly rosy beam. Packaging was a small bubble mailer with the light in a baggy and then wrapped in thin bubble wrap. Two extra o-rings were included. Before I try a 14500, which ones are recommended, flat top or button top, and which brand/model? What about length?
toddcshoe
toddcshoe's picture
Last seen: 1 day 19 hours ago
I use mostly Windyfire button tops. I have used purple Efest button tops and Amazon NiMh as well. Never had a single problem.
"Everywhere I go, there I am"
ActiveAl
ActiveAl's picture
Last seen: 1 month 1 week ago
I have three types of 14500 batteries (pictured below) which all work fine in my SS 14500/AA:
However, I typically use a  Ni-MH or primary lithium battery. I use my SS 14500/AA at night to make bathroom runs, so I don't need top performance. The SS 14500/AA  accommodates either flat top or button top batteries with no problems.
pennzy
pennzy's picture
Last seen: 3 hours 4 min ago
I use the Fenix 800mah protected.
SKV89
Anyone know hos to enable strobe on this thing? I accidentally added strobe to the main cycle of my Enogear stainless steel 14500 usb rechargeable. It was so annoying. But then I tried a bunch of random button presses and was finally able to get rid of the strobe? Anyone remember the UI since the Enogear website is no more.
BTW, I modded the Enogear 14500 w/ Optisolis 2700k and it works amazingly well. Needed a single DC-fix to smooth out the beam but beautiful perfect tint and color rendering. I also modded the Enogear AAA stainliess steel with the E21A 2000k and beam is perfect as is and very bright considering it’s a AAA light.
Anyone know anywhere to buy more of these?
ChibiM
ChibiM's picture
Last seen: 7 hours 54 min ago
Unfortunately I don't know.. Didnt know there was a hidden mode group either.
Henk4U2
Henk4U2's picture
Last seen: 4 hours 16 min ago
ChibiM wrote:
Unfortunately I don’t know.. Didnt know there was a hidden mode group either.
Ditto.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
Marnav1
Last seen: 2 weeks 5 hours ago
I bought the AA version quite awhile back. It failed with very minimal use. Asked for a warranty head, no support given. Not too happy about that :/
ThirdHandChain
ThirdHandChain's picture
Last seen: 11 min 15 sec ago
So is it the concensus of the group that the company no longer exists or is the website inaccessible from the US or what is the deal exactly? I purchased an enogear AA/14500 stainless used and it is an amazing light! I wish I could order more, I paid double the original asking price for the light and I still think it's worth it.
Not really a noob but I still haven't purchased a soldering iron.
THC
toddcshoe
toddcshoe's picture
You are correct. It is a great little light. There were a few issues with it. It seemed pretty hit and miss. Some had issues with it not working with AA’s after running LiIon’s in them. Or was it vice versa. I didn’t have any of those issues but I know some did.
You are right, Enogear is no longer around. The man behind Enogear is still around though, he is now the man behind FireFlies.
I emailed him some time ago to ask about any remaining Stainless AA’s. I didn’t get any response and I didn’t pursue it any further.
SKV89
I was able to buy some Enogears from Jack at Fireflies. It might take a few messages before he responds. I think he still stocks them.
toddcshoe
toddcshoe's picture
Thank you. I will renew my quest. I just figured he didn’t have any because of the lack of reply. I only sent one email. I am use to dealing with Chinese sellers and it seems keeping my email near the top of their inbox sometimes helps with getting a reply.
ThirdHandChain
Thanks gentlemen! I appreciate the information and I'll give it a try for sure. What currently produced light would you say is closest to the enogear AA/14500?
THC
toddcshoe
toddcshoe's picture
ThirdHandChain wrote:
Thanks gentlemen! I appreciate the information and I’ll give it a try for sure. What currently produced light would you say is closest to the enogear AA/14500?
I don’t keep up with all the new lights but I find the DGQ slim AA to be a similarly great light.
