The white stuff shows no flexibility at all, it breaks, and makes a scratching noise when I rub it with my forceps. It has at least the hardness of bakelite, or maybe it is ceramic.
I know, the CSLNM1 I have here are packaged in the same stuff. Again, I see no reason why this couldn’t be a filled silicone compound. It behaves like one under the tip of a soldering iron too (gets crumbly around 300°C, never melts). And the advantages in this application are obvious.
How could they cast ceramic around the die + phosphor + bond wires (nicely visible in your pic btw)? They clearly mold this in place.
Aaaaanyway… my point was that there’s fragile bond wires embedded in there and that may be why they mention not to put pressure on it.
There are ceramic adhesives which are used in bulbs because of low thermal expansion at high temperatures.
Just because it is “ceramic” does not mean it is solid like a rock.
It can be made into epoxies or other stuff.
This is the same thing as the 2mm white flat (CSLPM1.TG) but with a larger thermal pad for better overdriving capability.
There are no MCPCBs for it yet, hopefully LED4power will make some.
TBH I don’t think it’s a viable source.
But it is a source which is a small step towards general availability.
Though now that I think about it - I remember when Hank managed to source a batch of old XP-G2 long after they were unavailable.
From memory - 1000 was sold very quickly with several members buying hundreds each.
Boost HX is likely to stay the throw king for a while so it makes sense to stash them if GB promises a lower price than a store would. Though better bins may appear.
