I’ve been thinking about it more. Can we require that TK most preferably, or if not, someone else who will test and report, get a final prototype before we go forward? Is this possible? It might very well save a lot of issues in the long run.
Could anyone be kind enough to give a one sentence summary of where this is at?
Pages and pages of snips and snipes, giant collections of quotes nested 4 deep,…
Yeah, thanks Jon. I can see that on my own.
I was referring to it looks like that team isn’t there any more to update it and it’s all on TK and Neal now.
Won’t ask again.
Time is either ticking away (negative thinking) or moving forwards (positivity). Meanwhile this thing seems to be in limbo. And borderline chaos. Neal, since you seem to be "the man" here, please get a grip and try to sort things out, and communicate. Don't bottle it. Again. If you can't do such simple stuff (procurement etc.), send TK a proto3, nor set up the distribution chain in advance, well. I'd better say no more. Not expecting a reply :(
Time is either ticking away (negative thinking) or moving forwards (positivity). Meanwhile this thing seems to be in limbo. And borderline chaos. Neal, since you seem to be “the man” here, please get a grip and try to sort things out, and communicate. Don’t bottle it. Again. If you can’t do such simple stuff (procurement etc.), send TK a proto3, nor set up the distribution chain in advance, well. I’d better say no more. Not expecting a reply
Great post. Thanks.
Nope, he’s back to saying it’s in limbo and in chaos and chastising Neal for not communicating.
Current status: Trying to get answers. Attempting to pull something solid out of the cloud of possibilities, so there can be a more concrete plan and schedule. Most of the remaining tasks depend on Neal nailing down details and making commitments.
Aside from trying to get answers, about the only task for me right now is to build new firmware with the latest updates, test it on proto2 for a few days, and send it for production to use.
This keeps most of the levels pretty stable and reasonably efficient, as far as linear drivers go. But it still has a direct drive circuit for turbo.
In a totally non-scientific qualitative manner, the overall efficiency curve compared to a constant current linear driver looks something like this:
LEDs also change tint according to the power level. This driver attempts to minimize that effect by blending power channels, but it may still be noticeable. The curve for that looks roughly like this:
If I remember to, I suppose I should probably put this info in the first post somewhere.
Color temp / power ??
Should be efficiency / power, right?
Two seperate things.
The color can be effected due to the power delivery. The FET is full power, many amps, and uses PWM which pulses the full power to create the lower brightness levels.
The 7135 limits current, it only allows 0.35A through. So when it’s using 1 or all the 7135 chips fully, there is no pulsing or PWM and the color is slightly different.
It’s a bit complicated for me to follow, but the tint does shift slightly based on the type of power delivery to the led.
Using a prototype of the BLF-A6, I configured the firmware to alternate every half-second between 100% power on a 350mA channel and roughly 6% power (via PWM) on a direct-drive FET. The result was a constant amount of lumens but a changing beam tint.
OK BlueS, I was referring to your “it’s gonna take a bit of time.”
The price will be quoted when it is quoted.
Joking aside, my experience is large suppliers like this can usually provide quotes on items they deal with regularly in hours to a day or two during their regular hours, and if they have to work directly with a manufacturer on a special order of something that requires a little bit of special effort, it’s usually not more than a week.
Thanks ToyKeeper for the detailed response.
Being that its a Linear + Fet Driver, it should be more efficient with a high Vf LED correct?
The LH351D has a higher Vf than your typical Nichia so it shouldn’t heat up as much right at an equivalent output right?
Last but not least, does this light have a mechanical switch or an electronic switch?
If you define efficiency by led-watts/input-watts then a higher Vf would be better. However I would argue that the most important efficiency is lumens/watt-input and in that scenario you want the LED with the most lumens/amp where the VF doesn’t matter as long as it’s low enough for the circuit to work.
Moving forward at it’s own pace.
.................................. "Slow is Smooth, Smooth is Fast" ...................................
Texas Lumens Flashlights / M4D M4X Deals : sign up - save $$$$
Rudeness Level _ mΩ _ {width:70%} _ LightWiki _ LED Tint Chart
Xlamp size chart _ BatteryU _ Flashaholic? Need Professional Help??? TheOriginal _ TAB _ LightSearch _ BatterySearch _ 14500's _ DiCal
““Current status”:http://budgetlightforum.com/node/54239 (2018-11-28): Trying to get production started.”
How to hide signatures, and ignore someone, http://budgetlightforum.com/node/44835?page=3#comment-1438048
Won’t ask again.
Great post. Thanks.
KSGER STM32 2.1S Soldering Station Videos - Review Soon
Convoy L6 thread with XHP70.2, TA FET driver, Narsil v1.2 ramping firmware (old), lighted side switch, SMO reflector.
Supfire L5-S thread with XHP70.2, TA FET driver, NarsilM v1.0 ramping UI, 2 x 26350 cells, lighted side switch. My mini L6!
Thorfire S70S with MTN FET driver, RampingIOS (D4) and custom lighted side switch.
10 NarsilM user videos for BLF Q8, GT, GT70, GT Mini, Astrolux S43 and ROT66
Texas_Ace BLF Calibrated Lumen tube and Maukka Calibration Lights for DIY Lumen Measuring Devices
Headlight List with prices, specs and features - Jaxmnve M1 Stainless 10180 Keychain light Review - Lumintop ODF30 Review - Sofirn C8F 21700 Teardown and Review, Sofirn SP33 v2 XHP50.2 Review - My Sofirn Q8 Results - Astrolux S43S 219C Test Results - Lumintop GT Mini Test Results
If TK is cool with it, I’d vote for her to give it a once over before production starts.
Hoping this gets some more traction and we get a final prototype/render.
Interested in one.
Please put me on the list for one (LH351D)
Does anybody know what kind of driver the light will use. It says regulated up to 1000 lumens. Is it going to be a Linear 7135 based driver?
Driver:
Anduril based 3 channel driver, with 7135+7×7135+FET.
My very own high current Beryllium Copper springs: http://budgetlightforum.com/node/64047
The 3rd and “final” prototypes were already sent to 2 different people over a month ago.
We want the production version sent to someone close to Hong Kong as a final check.
Thanks BlueSwordM
Interest list updated in post #4.
- TK
FW3A thread
you are being facetious, right?
Pavlo, it’s a FET+7+1 driver.
So, three power channels:
2Q19
@chinookee, no, not at all.
I really sent Digi-Key a detailed quote for 800-4500pcs+ of LH351Ds in the chromacity bins we want.
Check ToyKeepers vid.
https://youtu.be/l94py6C_ld8
Of course it’s gonna take a bit of time.
The folks at Digi-Key are not going to be responding during the week end.
irony is hard to master, especially for me, I guess.
It is e-switch only. A mechanical switch would not allow for ramping (not easily anyway) and would take up much more space.
I’m looking for a dark grey light, so please add me to the list for one.
Definetily interested for one, please.
