The solution is simple if you use the original (Nanjg A47-AK etc) drivers in that light.
From personal experience I can say that with those drivers you don’t need a bleeder.
Just put a little 3mm led over the switch. And presto, you have your own redneck tailcap light.
So when the switch is on, the led is bypassed. When the switch is off, it is bypassed by the led.
Make sure you use a clear tailcap and a clear washer or you still won’t see a thing
The intensity of the led relies on the driver. 6-8*AMC7135 gets you more light than 2-3*AMC7135.
If you use the new Convoy drivers (with biscotti firmware), lighted tailcaps won’t function as they should.
Not with any given combo of resistors. And that is not the only aspect they react with quirky behavior
i presume its original one , it the cheapo 3/5mode off gearbest. no stars on driver 6 chips. but i flashed it with biscotti and thats when funny behaviour started.
ill try adding another resistor, (guessing that will half ohms). maybe 560 is too high.
I have that one as well. It’s in an Eagle Eye X2R. The 330 ohm resistors are kind of too low resistance. I plan to change mine to 1000 - 3000 ohm and then see if my 680 ohm bleeder resistor works. Right now I’m still getting the next mode memory problem.
The leds are not very bright considering they use 330 ohm resistors. Switching to 10k might make them super dim. I was going to 3x to 6x their resistance first and see if it works without getting too dim.
This kind of stuff makes me want to use a trim pot on the leds.
