The Imalent RT35 flashlight has a maximum output of 2350 lumens from the Cree XHP35 HI LED and is powered by 4 x 18650 Li-ion batteries. Offering excellent output and an incredible throw up to 1338 meters, the torch is the ideal searchlight for applications requiring a far throwing beam.
The RT35 features innovative magnetic charging, simply attach the included cable to the magnetic plate on the side of the torch to recharge the batteries. Removing the requirement for an external charger makes the torch more portable and allows for quick and convenient charging on the go.
Five output levels, ranging from 50 to 2350 lumens, and a hidden Strobe mode ensures you can have a long runtime with low output or high output when required, so you can prepare for your night time outdoor adventure well in advance. The RT35 is fitted ith a user-friendly side pressure switch to operate the output selection. Tucked neatly below the switch are three multi-functional charging indicators which flash red when the battery voltage is lower then 3.2V and change from red to green when the batteries are fully charged at 4.2V.
Main Parameters:
LED: Cree XHP35 HI LED
Power Supply: 4 × 18650 battery
Beam Distance: 1338 meters
Peak Beam Intensity: 449000cd
Max Output: 2350 lumens
Waterproof: IPX-8 standard
Impact Resistant: 1.5m
Output and Runtime:
Turbo: 2350-1500 lumens ( 8+162min )
High: 1500 lumens ( 3h 45min )
Middle: 750 lumens ( 6r 10min )
Middle Low: 350 lumens ( 12h 45min )
Low: 50 lumens ( 60h 162min )
Product Features:
● Utilizes one American XHP35 HI generation LED, with a lifespan of up to 50000 hours and a maximun output up to 2350 lumens.
● Built-in safety self testing intelligent charging circuit, convenient, fast and safe.
● Exquisite, powerful, extremely long throw at over 1300 meters.
● Built-in intelligent temperture control module can automatically adjust the brightness output.
● Built-in magnetic charging, higt grade and portable.
● 6 levels which can be exchanged quickly and instant turbo.
● Battery capacity indicators besides power switch, shows the capacity any time.
● High efficiency caonstant current circuit will maintain constant brightness.
● Combination of toughened ultra-clear mineral and anti-reflective coating glass.
● Aluminium OP reflector.
● Aerospace-grade aluminium alloy body, wear-resistant Type III hard-anodized surface treatment.
● IPX-8 standard waterproof (2 metres submersible).
● Built-in multi-functional charging incicators.
▹Function 1- Lower power warning:
When the battery voltage is lower than 3.2V,the red indicators will turn on.and if users try to activate turbo mode,the red indicators will flash three times to remind users battery too low to activate it.
▹Function 2 - Charging:
The indicators will be red when it is charging and turn green when it is fully charged to 4.2V.
This light is incredible for spot lighting and adventure sports requiring a long distance throw. With the coupon code "IMRT35" of GearVita, you can get this throw king of $74.95. Look at it, you will find out the discount is super: https://gearvita.com/imalent-rt35-led-flashlight-2350lm.html
Related products:
nitecore concept 2
imalent ms12
