13583 posts / 0 new
maukka
maukka's picture
Last seen: 36 min 37 sec ago
Jerommel wrote:
Yeah, i know, but then the graph suggests the color temp gets cooler when power increases, which is not the case. LEDs have a cooler tint when running on low power, get warmer tint when power increases.
This depends on the LED but most I’ve tested have gotten cooler with increasing current.
USA
USA's picture
Last seen: 1 week 4 days ago
I am new to this board and don’t know all the details of this project – just wanted to thank everyone involved and say that this product appears really innovative and cool. An electronic tail switch is something I haven’t seen before in this form factor.
Agro
Agro's picture
Last seen: 15 min 45 sec ago
ToyKeeper wrote:
Pavlo, it’s a FET+7+1 driver.
So, three power channels:
  • 1xAMC7135 chip for 0 to 350mA
  • 7xAMC7135 chips for 350mA to 2.8 A
  • FET for 2.8 A to full power (direct drive)
This keeps most of the levels pretty stable and reasonably efficient, as far as linear drivers go. But it still has a direct drive circuit for turbo.
In a totally non-scientific qualitative manner, the overall efficiency curve compared to a constant current linear driver looks something like this:
You did mention that efficiency is “reasonably efficient as far as linear drivers go”. But the charts themselves look as if the blue curve was optimal, not merely optimal for linear drivers. I’ve been confused by them when I was more noobish than I am now. I suggest clarifying that right on the pictures.
Also, I believe that Emisar D4 tests have shown that FET was not as inefficient as people predicted, though I haven’t seen a careful analysis of what was going on, one that would enable us to draw lessons for future drivers designs.
djozz
djozz's picture
Last seen: 9 hours 8 min ago
A led driven to the max is inefficient for two causes: high current and high heat. A FET driver at PWMed lower modes has one cause (heat) removed so the led during the pulses runs at higher output than if at max continuously.
It really works like that. Example: I made a 18650 zoomie with a Osram KW CSLNM1-TG and FET+1 driver. If I use a high current cell it is overdriven at max resulting in angry blue light. But at slightly lower setting (so still high in the FET region of regulation) the led colour is normal. The led still receives the same current (but pulsed) so the difference I presume is caused by less heat.
Tom Tom
ToyKeeper wrote:
tatasal wrote:
Deep from the abyss, now comes this photo of the FW3A …
What do you think guys?
No major host shape changes have been approved, so I hope that’s just unscrewed and missing the clip and O-rings.
I also think it’d be nice if the people involved in the project didn’t have to get news from forwarded social media posts. It’s a bit frustrating.
Open the photo in a new tab, zoom in (there is a lot of detail there to see), and you can form your own opinion. Those don’t look like o-ring grooves to me. And if they are, why two ? This isn’t a dive light. And the clip was not supposed to clip into a groove, but be Solarforce style, with integral retaining ring.
Or just go straight to https://i.imgur.com/rohcLIc.jpg[/img]
There isn’t a separate tailcap as such in this design, the tube should only ever unscrew at the head, so if this really is just a display of parts in disassembled condition, well, why ? Screw it up please Wink
Remember, this is where the concept started: http://i.imgur.com/AVSmLGN.jpg It seems a lot has been coarsened since then.
Nice touch putting the piece of packing under the Emissar, and bringing it forwards, to make it look longer
Edit, and fatter
Than it actually is Crying
I do hope I’ve got this completely wrong, but I don’t see (literally) how I could have.
PBWilson
Last seen: 4 hours 36 min ago
The design may have something to do with ease of manufacture for Lumintop. I wonder if one of their other lights is similar enough to the design in the photos and instead of setting up tools and fixtures to make a light exactly as Fritz had envisioned it, they are going with their own designs.
JoeRodge
Last seen: 3 days 13 hours ago
Get me on this list for +1 please
joechina
Last seen: 1 month 5 days ago
Geuzzz wrote:
Great color as is. I like the slight green in there.
Really?
I dont see green in the middle of the tubes.
I would guess its the reflection from the green table.
nvanlaar
nvanlaar's picture
Last seen: 8 hours 17 min ago
JasonWW wrote:
ToyKeeper wrote:
I think no host changes have been approved and somebody has some explaining to do.
There might not be any host changes. It’s looks pretty much exactly like it’s supposed to.
It’s just the ends being unscrewed that make it look different.
Why would there be two o-ring grooves on the head side? I thought the clip was designed solely to go on the tail hence the revised chamfered portion.
“Facts don’t care about your feelings.”
~Ben Shapiro
Firelight2
Firelight2's picture
Last seen: 1 hour 18 min ago
That’s what it looks like to me too.
At the tail it looks like they’ve cleared a groove for a slip-on clip. If that was merely the tailcap not fully screwed in the interior of the groove wouldn’t be completely smooth. It would have threads and an o-ring slot near the top.
I’m also not quite sure about the groove at the top of the picture. It looks like it has what might be an o-ring slot, but no threads. Did Lumintop just decide to put a decorative groove on booth ends and the light in their picture IS actually fully screwed together?
Geuzzz
Geuzzz's picture
Last seen: 2 hours 6 min ago
joechina wrote:
Really?
I guess you are not a tint snob Smile I unfortunately am and I developed a spider sence for green.
cabfrank
Last seen: 6 hours 16 min ago
I can’t imagine a reason for posting a picture with the parts not screwed together. It doesn’t make sense to me.
toddcshoe
toddcshoe's picture
Last seen: 1 day 22 hours ago
Oh for the love of baby jesus. Please tell me they aren’t going to put a damn snap on clip on this light. That I think, would put a bunch of folks over the edge.
"Everywhere I go, there I am"
Firelight2
Taking a third look at the picture I now notice a decorative groove on both ends of the battery tube. The groove is the recessed area with raised ridge in the center.
Why do I think it’s a decorative and not just the light partially unscrewed? …. the grooves have no threads in them.
Though maybe I am wrong and those are just slots for double o-rings. I don’t think so though. If it was for double o-rings I would expect the same groove depth at both ends of the battery tube.
In addition to the decorative grooves, the bottom of the battery tube has a larger flat area just above the decorative groove that looks clearly designed for a slip-on clip.
Personally, I don’t like this new look. Looks overly complex. I much prefer the previous prototype.
Geuzzz
Geuzzz's picture
Agreed. That would go against the whole concept.
cabfrank
I tend to agree with you, and if so, it is quite a departure in design.
Linburger
Last seen: 2 days 13 hours ago
Please add me to the list.
Thanks
Tally-ho
Tally-ho's picture
Last seen: 2 months 16 hours ago
When comparing the proportions it’s pretty obvious that, like it was said, head and tailcap are unscrewed.
> photoshopped >
Tom Tom wrote:
Screw it up please
Have a look above and next please…
Jerommel
Jerommel's picture
Last seen: 5 days 18 hours ago
Really??
Or maybe you mean this is the case in the range above very low modes.
Very low modes like ‘moon’ and ‘firefly’ give relatively more blue, i guess the phosphor is not excited by very low levels of 450nm.
Tom Tom
But why post that ?
Makes no sense.
Screw it.
And please someone send some proto 4s to the people who are still trying hard, not being lackadaisical.
Jerommel
Jerommel's picture
You are most probably correct in that observation.
Sure hope so !!
nvanlaar
nvanlaar's picture
That is the coarsest threading I have ever seen on a light… or… possibly an o-ring slot and a slot for a snap-on-clip. If it does screw together and cover the two slots, that seems like wasted space.
*I reserve the right to be completely wrong.
~Ben Shapiro
CRX
CRX's picture
Last seen: 2 hours 48 min ago
Double o-rings, good design.
- LEDs & Other Stuff -  - UI CheatSheets -  - CRX Mods & Builds -  - Stuff for Sale -CRX Hand Made FlashlightsThe only place that fear can exist is in our thoughts of the future.
It is a product of our imagination causing us to fear things that do not presently and may never exist. Fear is a choice.
Firelight2
Yup. If those actually are double-o ring slots, that would be good design.
However, at the tailcap, the upper ledge of the “o-ring slot” seems like it would be too shallow to actually hold an o-ring. Screwing in the tailcap would push that o-ring out of position.
CRX
CRX's picture
Thinner o-ring Smile
Tom Tom
I really don’t think so. Unnecessary, and other aspects that I have observed on this image are troubling.
For starters, putting an o-ring into a rough bead-blasted groove with some shonky anodising is really not cool. If you want to create a seal, do it competently, or don’t bother. That means precise machined surface finish and materials selection. Slathering it with grease may also help. If you dive, you might understand this a little.
But since this is what it is, it probably doesn’t matter at-all to most customers.
It’s not as if we have even seen these supposed double o-rings in-situ. Well if two are better than one, why not three, or four where do you stop ?
Do it properly and one is enough. Two maybe for a dive torch, but that comes with downsides too. Double the maintenance, and you never really know whether either, or both, are serviceable. A bit like flying twin-engine planes.
CRX
CRX's picture
Is that a piece for sale?
What do you want for thirty odd dollars, rocketship precision?
Jerommel
Jerommel's picture
You could maybe take it diving with double O-rings.. Silly
tatasal
Last seen: 2 hours 34 min ago
Btw, talking about double O-rings in non-dive lights:
CRX
CRX's picture
Lot of maintenance there…
