The Nichia 219C is a pretty small led. You have to push it hard to get decent output. The harder you push it the less efficient it becomes. More and more of the input power gets converted to heat rather than output.
Plus it seems the bezel is robbing output. I get and extra 500 lumen on turbo without the bezel.
Usually the people that prefer the Nichia usually know it’s not going to be as bright as the xpg2 and accept it. Your trading that extra output for the nicer tint.
It’s unfortunate that the bezel blocks off such a significant amount of output. Thanks for the info. 18A is alot of current. My multi-meter only measures up to 2A Do you have a link to the best method/equipment to take current measurements for flashlights?
1. Use a current shunt, like 10mOhms of 16AWG wire to know the specific voltage drop to calculate the current, on the tailcap. That’s my method, as I don’t need a current meter for now.
Yeah, but if you get 2000 lumens from four emitters, that’s only 500 lumens per emitter average. Even at 2600 lumens, it would only be 650 lumens per emitter. If it is using 18A to get there, that’s 4.5A per emitter, for an efficiency of less than 50 lumens per watt! That’s atrocious!
According to CREE PCT, the old XM-L in the LOWEST BIN, got an efficiency of 50.7 lumens per watt at 3 amps. So, this 219C is getting less than 50 lumens per watt at 4.5 amps, marginally better than the lowest bin XM-L of decades ago.
Well, I mean, the 219C has an efficiency of 69,6lm/W at 4,5A.
If you count the inefficiencies of the circuit, like the dual phosphor bronze springs having higher resistance than a single BeCu spring for some reason, and the less efficient optics, and thinner traces of the driver, no wonder the S43S is less efficient than even the Emisar D4.
Don’t forget the 219Cs in Astrolux’s tests may be lower binned than Intl Outdoors’ LEDs, and what not.
Just got my S43S NW today. My Texas_Ace lumen tube measured the same 1200 top of ramp, 2000 turbo using keeppower 18350 cells. Drains the cell really, really quick
I recommend everyone with this light to reset the temperature stepdown. In stock form it gets too hot then steps down to about 60 - 90 lumen. That’s no good.
I reset mine to step down a bit sooner. Now it acts much nicer and takes multiple small step downs over time.
I did a video. The 30Q was not fully charged due to a few turbo runs the day before so turbo output is a bit low.
35 seconds at Turbo
23 seconds at 550lm
23 seconds at 285lm
23 seconds at 130lm
Then steady at 87lm
I’m not sure I understand correctly, do you mean if the thermal temperature threshold is set lower, the stepdown will be in smaller steps? Though would step down faster when in Turbo mode?
I've been puzzled by these references in some reviews to the sudden fierce thermal regulation step down from turbo of the S43 and S43S. My S43S as out of the box unaltered (ordered early November, arrived about a week ago) has always stepped down in a sequence of steps like those you cite after lowering the thermal regulation temperature. The first step down from turbo varies quite a bit depending on the state of charge of the battery and which battery. I've seen a 43 sec minimum and a 110 sec maximum. After that the subsequent steps down always take place at regular intervals of around 23 seconds. It's the same behaviour whether I use a 30Q 18650 or an 18350, except that a fully charged 18350 can't reach the same initial turbo brightness or short time as the 30Q.
I’m sure Tom E could explain the NarsilM thermal stepdown behavior in detail.
Keep in mind that the thermal sensor for the driver is built into a chip on the driver itself, the Atmel ATtiny MCU, so there is a certain delay and inaccuracy associated with it. Still, it works pretty well on lights that heat up a bit slower. On these small lights that heat up super fast it can sometimes cause the software to act funny.
ToyKeeper has tweaked the Anduril UI, which is going to be used on the forthcoming FW3A, to be more of a thermal control as opposed to a thermal stepdown. The FW3A also gets hot very quick, but once it cools it can actually go back up in brightness. It still uses the ATtiny chip which is what most of the BLF user interfaces are based on.
I have some notes on NarsilM v1.0 and it says the mcu samples the temperature after the initial stepdown every 45 seconds in order to give the temperature a bit of time to stabilize. It seems newer versions have cut this time in half. Probably every 22.5 seconds, which is why we see it adjust in 23 second increments.
That’s my experience, too. My only complaints are that
1. It steps down too far. As mentioned, you end up with less than 100 lumens by the time its done.
2. It never steps back up after it cools off.
Okay, I get that (2) is probably not going to be implemented in a budget light, so I’m okay with that. But (1) should really not happen. Perhaps the firmware should have a “pause” limit of something like 300 lumens, and stay there for a few minutes before it tries further step-downs.
OTOH, last night I was out walking in –16C temperatures, and used turbo for several minutes without any step-downs at all. So, the temperature sensor works okay. Unfortunately, turbo produces way too much heat for any decent run-times at room temperature. But outside in winter, it’s much more useful.
If it’s doing one giant stepdown, try what I mentioned earlier. Reset the stepdown temperature a little lower. After doing this I got several smaller stepdowns instead of one big one…
I believe the head heats up quicker than the thermal sensor heats up. So by the time the thermal sensor gets to 55°C (IIRC), the head is already well beyond this. Resetting the sensor based on how hot the head feels seems to work better than the factory setting.
problem is the MCU firmware can't detect lumens output - all it can control is relative output and it doesn't know even what amps is going out, yet alone lumens, and the firmware, least how I wrote it, is for generic lights, not specific LED, host, and battery configurations.
Also the temp in the MCU is disconnected from the temp at the LED(s) and temp you are feeling on the body. It's a very imperfect system. External temp sensors at the proper places would help for sure, but still the algorithms aren't trivial.
However Zebralight does their thermal control, works extremely well. I’m guessing they use some integrated approach (and maybe expensive) that isn’t practical in this light.
As a possible partial-solution, could the firmware you wrote not be tweaked for whatever host is using it? For example, in this light, it could start at a lower temperature, and each time it steps down it could raise the temperature threshold a bit. That might slow down the step-downs, and allow the light to settle down at a higher output.
