Good call. And thank you TK so much for confirming it with Neal.
Not sure why doing a nice anodise should be proving so tricky, isn’t that what anodisers should just know how to do, it’s their job after all ? Perhaps it’s to do with the alloy used. ISTR that it also took Convoy a while to develop their clear anodise to their satisfaction.
A clear anodise on a “raw” machined finish is also merciless in exposing the slightest defects in workmanship, when the machining marks are to be a design feature, not something to be covered up. Just handling the pieces, moving them around, keeping them almost surgically clean before processing, etc. needs care, individual bubble wrap etc. if you don’t want them dinged up, then a good hard anodise to then protect them. Unlikely to be real mil-spec HA3 stuff, but still something good, semi-hard.
It was probably unrealistic to hope for anything like that at this price-point.
Bead blast, a quick dunk in the tanks, then just chuck them all in a bin together is the production-engineering easy way out.
The solo artisan perfectionist, toiling at their lathe, can make things much more beautiful, and go from concept to execution in a few hours, but that doesn’t easily scale, as I think we are discovering.
Sitting behind a CAD screen, rendering, then perhaps coding for CNC (that’s usually a different, more practical, and dare I say more skilled discipline), is not quite the same thing as making swarf, and sometimes pieces don’t turn out quite the way it was hoped, or are simply un-manufacturable, and another iteration is required, and things can become delayed interminably. The skill is not to let that happen. And to use a team to review, accept constructive criticism, involve the production people as early as possible, and not just live in an ivory tower.
It looks as if they have got a nice looking bland result.
For those interested, you could take a look at e.g http://www.metroplating.co.uk and study their “services” options. Each provides a succinct summary of each process. Specialist finishers like these are crucial to the UK’s manufacturing competitiveness, particularly in motorsport, aerospace and defence, and metroplating one of the best and most nimble IME. There are hundreds more though to choose from, just Google e.g. “anodising uk”.
Something for modders to experiment with, and a bit more creative than e.g. just baking your torches.
Start with something cheap, strip off the old with sodium hydroxide (e.g. some drain cleaners), maybe buff it up a bit, and get practicing. Some battery acid, inkjet printer ink, some sort of DC power supply, a cathode, some Al wire, and you’r good to go. Perhaps in time for the 2019 Old-Lumens challenge. Use titanium instead, and apply by brush, use masking, and you could make a really unique work of art.
So, BOD is enabled. Without BOD, it’s very difficult to exit momentary mode because the standby drain is too low. It took several minutes to drain far enough to cause the driver to reboot, and with BOD it’s only a few seconds. This should also help avoid other theoretical issues with low voltage.
Factory reset isn’t included, because it’d cause too much delay making sure there are no bugs. I did a quick proof of concept but there were too many issues to move ahead with the change right before production. So I went back to the 12-02 version which, despite the date indicated, has been under test for about three weeks on various lights. It’s virtually identical to the 11-11 version.
Anyway, it seems things are finally moving quickly.
However there IS a nice subtle design aspect of the FW3A body I do like A LOT which stands out. The sleekly well-crafted ‘combat grip’ ridge right above the tail cap. Extremely useful and a feature I wish many of my rear switched single-cell flashes had incorporated.
Elegant simplicity.
I may buy this just for this brilliant point alone and the way it was executed.
Kudos to the brain that insisted it being there.
:+1:
PS. I wanna clarify that this finger grip ridge isn’t uncommon per se. Just that it appears the FW3A’s is actually large enough for even glove wearers butt yet isn’t too large as to be ugly and out of proportion to the rest of the outer design. Plus it looks well smooth machined and thus comfortable. Sharp ridges and fingers pressing down don’t work for me. :sunglasses:
It is like LVP, but built deep into the attiny85’s innards. Basically, if voltage drops below 1.8V at any time, even for a few microseconds, it’ll stop code execution completely. The main purpose of this is to make sure the MCU won’t attempt to do anything when it’s out of its supported voltage range, because its behavior is unpredictable when voltage is too low. This helps prevent random eeprom corruption and things like that.
The benefits outlined in the attiny manual don’t seem to matter for flashlight purposes, but it doesn’t hurt. I’m using BOD for its side effect — increasing standby power. Because it makes no difference to battery life but it makes a lot of difference when attempting to exit momentary mode. Without BOD, it could sort of get stuck in momentary mode because there was no fast way to force residual power to drain.
Without BOD, standby power was so low I had to use a high-end 6-digit Fluke meter to measure it. So, basically zero. Or ~0.0001 mA, if I recall correctly. This is impressive, but too low for this purpose. So with BOD, standby power is about 0.02 mA. Low enough to be negligible for battery life, but high enough to make the light shut down only a second or two after power is removed.
