Is there an individual triple LED Driver with 2 modes per LED?
I found this one on KD:
http://kaidomain.com/S026866-KZ-3016-Individual-Triple-LED-20mm-1_5A-2_7V-4_5V-Driver-Circuit-Board
Is there an equivalent on the market which delivers 2 modes per LED?
I want t omod a S2+ with 3 different colors and want a low and a high mode for each color.
Cheers
That one can have each LED either on or off. Sounds like two modes to me. :smiley:
You might not be able to use that driver without some mods anyway. Different colored LEDs take different voltages.
Haha, got me :smiley:
Umm, im not that modding proā€¦ hope i mustnt change the driver =(
In the german TLF a guy modded his Convoy with that driver and took a red, a blue and a nichia LED. He didnt mention that he has to change the driver.
ĀÆ\/ĀÆ
If it worked for them, it worked for them.
Either way, it doesnā€™t have the UI you want.
Thats correctā€¦ but if there is nothing on the market i have to take this one.
Thanks for your help!
@milli111, ask Kaidomain to put different modes on the driver of the light.
They accept customization options.
http://kaidomain.com/I3N-20mm-3V-9V-1_5A-1-cell-or-2-cells-6-Mode-3-Individual-Channel-Driver-Circuit-Board?search=I3
Thatā€™s the driver they use for their triple color XP-E2 dropin, but itā€™s the wrong size for a Convoy S2. The S2 uses a 17mm driver.
The inner diameter of the S2+ tube is almost 20.8 mm. If you find a way to attach the driver to the pill it is doable.
So this will illuminate all three emitters? Not just #1 or #2 or #3?
@ggf31416 this one sounds interesting! Thanks for the link.
And this one controls every single LED after the other? So i would have red high, red low, green high, green low, blue high, blue low for example? That would be nice.
Like TBone said, i think the 20 mm should fit.
The ā€œā€Sharp Eagleā€ aka nut light
zoomie reviewed here a few years ago acted like that.
Cycled through high/low using individual cool, warm, and blue emitters.
Iā€™d hoped for a 1, 2, or 3-emitter driver but no.
I found the review of the drop-in that uses that driver.
FYI beyond of the driver only and P60 drop-in format they also offer the PCB with the leds and optics as well as the drop-in bundled with their E6 P60 host.
I checked this one out, but i would like the Convoy S2+ host because of its smaller size and the possibility to use the short tube.
Thanks a lot anyway!
This PCB is used for S2+ triples.
The optics included is compatible to Carclo 105xx. 20 mm diameter but shorter than the original reflector. You will need a (D20*6 mm) spacer on the pill that will give you the D20 mm surface for the PCB. (Example)
