Thanks for the info TK! I can tell Jack don’t frequent the forums often otherwise he would have known you like the 219B 4500k 9080 version.
But since you have both the XP-L HI 1A and 3A, can you take some lumen measurements to compare them. Because FF is listing the 3A as a V2 flux bin and the 1A as V3 flux bin. The 3A is also specified at a lower output than the 1A. For the ROT66, both 1A and 3A emitters are V3 and FF publish the same 10k lumen output for both.
I’m wondering if and why FF decided to change from V3 to V2 for the 3A XP-L HI.
My light box maxes out well below the E07’s turbo level, and I don’t even have a high-amp 21700 cell to use. I’ve been sticking to high-mAh cells instead.
Do we have to order from Neal. Nothing against Neal, I prefer to order on Fireflies site. Will there be another code like with the ROT66 and PL47 which works on his site directly?
Hey, TK. how about a pic of fw3a in V’s hand and the e07 in the other? I Might get one for the wifey. I almost had a heart attack when SHE asked ME for a new flashlight because the last one wasn’t bright enough. Congrats on your new lights for a job well done. I think Jacky got the auxiliary LEDs colors right for you!
Maybe next to a ROT66, but probably not a D4/D4S. It seems a bit rude to make a public comparison of two competing clients’ products, especially when both are some of the best on the market.
Also, this is only speculation, but I get the impression that FF may be intentionally avoiding direct overlap, by choosing different form factors and different battery types and different aesthetics. I don’t think the items are meant to be directly comparable. It’s a form of playing nice, and I want to respect that.
a picture next to the rot66 would be nice. and just to verify, the aux leds on the side switch are purple, correct? are the purple leds on the head the same purple as the side switch? are the optics the same size a the rot66, or smaller?
I’m mostly interested in sustained high and effiency.
I guess I’ve too wait for a review too know the sustained high?
Anyway which option is most effecient? Is the light with the most lumens on turbo also the light that’s most effecient at, say, 1000 lumen?
If there is an effiency difference how many percent would that be?
