Test/review of DMM Mustool MT109
3 posts / 0 new
HKJ
HKJ's picture
Last seen: 5 hours 27 min ago
DMM Mustool MT109
DSC_4099
This is a smaller meter that has a lot of ranges.
DSC_4093 DSC_4094 DSC_4095 DSC_4096
DSC_4097
I got the meter in a brown cardboard box, the drawing mostly matches the meter.
DSC_4098
It included the DMM, a pair of probes, a thermocoupler and a manual.
DSC_4100
DSC_4101
DSC_4102
The probes has is rated for CAT III, but do not include the partial tip covers required for CAT III or CAT IV.
DSC_4103
The shrouded plug is the slightly short variety.
DSC_4105
DSC_4106
A standard cheap thermocoupler.
DSC_4111 DSC_4155
The range switch is a bit difficult to use single handed when meter is on the tilting bale, it slides around.
DSC_4107
DSC_4108 DSC_4109
DSC_4158
There is a flashlight led on the front of the meter.
DSC_4110
DSC_4201
DSC_4202
DSC_4203
DSC_4204 DSC_4205
DSC_4206
DSC_4112
Display
DSC_4117
The above picture shows all the segments on the display, not all are used.
DSC_4118
Typical display during usage, it will show the number and what measurement is selected.
DSC_4119
The NCV is the usual bars and the buzzer.
Functions
DSC_4120
Buttons:
  • Select (White): Select the ranges printed with yellow.
  • Hold: Freezes the display, hold down to turn off backlight (Display is not readable with backlight off).
  • Range/Rel: Will disable auto range and change range, hold down to activate auto range. In capacity mode it will zero the reading.
  • Max/min: Starts recording maximum and minimum value, press to select between max/min/disable. Hold down to turn the flashlight on/off.
MAX/MIN will change to manual range and return to auto range when disabled.
Rotary switch:
  • Off: Meter is turned off
  • VAC: Show AC voltage, using the Select button to select frequency and duty cycle.
  • VDC: Show DC voltage.
  • mV: Show mV, use Select to change between DC and AC
  • ohm: Resistance, diode, continuity, diode, capacitance.
  • Hz: Logical frequency and duty cycle (Use Select to change between them).
  • A: Current DC and AC (Use Select to change between DC, AC, Frequency, Duty-cycle).
  • mA: Current DC and AC (Use Select to change between DC, AC, Frequency, Duty-cycle).
  • TEMP: Temperature, used Select to change between Celsius and Fahrenheit.
  • NCV: Non-contact voltage or electric field detection.
Input
DSC_4121
  • 10A: High current input
  • COM: The common terminal for all ranges.
  • xxx: All other ranges.
Measurements
  • Volt and frequency
    • At 100mVrms in VAC frequency range is from 1.3Hz to 6kHz
    • At 2Vrms in VAC frequency range is from 1.3Hz to 60kHz
    • VAC frequency range requires a zero crossing.
    • At 0.1Vrms frequency input range is from 1.0Hz to 5MHz
    • At 2Vrms frequency input range is from 1.0Hz to 65MHz
    • The frequency input requires a zero crossing.
    • Duty cycle works from 2% to 99% at 100kHz with 1Vpp, precision is within 0.3 (Mostly 0.1).
    • Max/min needs about 500ms to capture a voltage with repeating pulses.
    • 1 VAC is 5% down at 2.1kHz (RMS will not work at the frequency).
    • Input impedance is 10..11Mohm on DC and AC
    • Frequency input is above 1Mohm up to around 1.5 volt, then the protection clamps to 2kOhm
    • Overload protection on DC is 1000VDC and 750VAC peak, except mV range is 550V DC or AC peak.
    • Overload protection on AC is 750V rms
    • Overload protection on frequency is 550VDC and AC peak, but meter may be damage at 250VAC peak (This is what the specifications says).
  • Current
    • mA current is protected by a 0.63A/250V or 0.6A/250V 5×20mm glass fuse.
    • A current is protected by a 20A/250V (Circuit board and manual says 10A) 5×20mm ceramic fuse.
    • The A range has an audible alarm at 1A, i.e. beeper sounds all the time when current is 1A or above.
    • The A range is slowly drifting when current is near 10A (About 0.6% in 30 seconds).
    • The mA range has an audible alarm at 1A.
    • Current ranges must only be used up to 36VDC or 25VAC
  • Ohm, Continuity, diode and capacitance
    • Ohm needs about 2.8s to measure 100ohm
    • Ohm is 1.0V open and 0.33mA shorted
    • Continuity is fast (About 15ms).
    • Continuity beeps when resistance is below 50ohm.
    • Continuity is 1.0V open and 0.33mA shorted
    • Diode range uses 3.2V, max. display is 3.000V at 0.1mA, max. current is 1.4mA shorted
    • 10uF takes about 4.2 seconds to measure.
    • 11000uF takes about 9.5 seconds to measure.
    • 70000uF takes about 9.5 seconds to measure.
    • Overload protection is 550V DC or AC peak
  • Miscellaneous
    • Current consumption of meter is 32mA and 41mA with flashlight on.
    • Meter “works” down to 2.1V where it turns off, battery symbol show at 2.3V.
    • Backlight works down to about 2.6V, below that the display is unreadable, except with a bright light on it.
    • Reading changes with voltage and 9V is down 6 count at 2.6V.
    • Flashlight changes with voltage and works down to meter turns off.
    • The meter usual shows the correct value on the first display update.
    • Viewing angle is good, except from top.
    • Display updates around 3 times/sec
    • Flashlight can be manually turn on/off and will turn off when the meter turns off.
    • Will automatic turn power off in about 180 seconds with a warning at 120 seconds
    • When auto power off is disabled the meter will sound the buzzer at 120 & 180 seconds about every 15 minutes.
    • Standard probes cannot be pushed fully down.
    • Weight is 209g without accessories, but with rubber sleeve and batteries.
    • Size is 145 × 70 × 37mm with rubber sleeve.
  • Probes
    • Probe resistance 40mOhm for one.
    • Probe wire is soft and 73cm long.
1uF
A look at the capacitance measurement waveform.
DMMInputVoltageSweepHz
Frequency input resistance depends on input voltage.
DMMInputVoltageSweepmVDC
As usual mVDC has high input impedance at low voltages.
DMMschema
Ohm specification goes to 60Mohm
AC voltage may show low voltage when large DC offset is present.
Tear down
DSC_4207
There where four screws holding the meter together.
DSC_4209
DSC_4208
The circuit board is rectangular with most parts on the other side.
DSC_4210
DSC_4211
Six more screws and the circuit board could be removed.
DSC_4212
DSC_4214
This side has the fuses, the PTC, the buzzer, the flashlight led and the crystal for the multimeter chip, basically anything that needs some space in height. The mounted A fuse is a 20A fuse, but the circuit board is marked 10A. For the mA range a 600mA/630mA fuse is used, this is a bit low for a 1000mA range.
The two points marked RCAL2 is accessible from the battery compartment without opening the meter.
DSC_4215
DSC_4216 DSC_4218
DSC_4217
DSC_4213
At the bottom near the input connectors are the current shunts, 0.01ohm wire for 10A and 0.99ohm for mA, this resistor is a bit small for 1W. There is also two MELF resistors for voltage input (2×5Mohm). There a transistor pair (Q3 & Q4) for protection together with the PTC. As is usual the case with cheap meters safety is based on a single SMD resistor (R53: 900kOhm), that will be directly connected to the input terminal in some ranges.
The PTC and transistor clamp is used in all ohm and frequency selections.
THE NCV antenna is at the top of the circuit board.
The multimeter chip (Circuit board says HY12P65) has an external calibration memory (24C08N)
DSC_4219
DSC_4220 DSC_4222
DSC_4221
Conclusion
As usual CAT rating is overstated with 250V fuses and a single PTC it will not handle CAT III 1000V or CAT IV 600V.
The meter is fairly nice with 9900 display, but there is some missing ranges and way to much noise from the buzzer when measuring ampere and the mA range cannot handle the rated current for long. The max/min is a nice function, but it is rather slow.
It is a nice meter for around the house or hobby usage, as long as it is only occasional usage, due to the fairly short battery lifetime.
Notes
The multimeter was supplied by Banggood for review.
How do I review a DMM
More DMM reviews
Barkuti
Barkuti's picture
Last seen: 28 min 54 sec ago
Interesting. Given its rather high current consumption and high “display cut-off” (2.6V) this will hardly be able to use ⅓ of the total capacity from alkaline cells. This means modifying its battery carrier for parallel operation and installing LiFePO4 cells inside would be a good idea, don't you think?
I like being able to shut off the auto power off annoyance. Together with removal of the buzzer from the board or hitting it with a hammer fixes this meter. Big Smile
Fair price too, wonder what are the main differences versus Aneng AN8008 and AN8002 (Zotek ZT109 and ZT102).
Cheers Smile
HKJ
HKJ's picture
It is about the same, you can use my schema to compare the differences.
