That little boy showing respect is SO CUTE! Well done young man! (And of course Fireflies… )
Copyright in General (FAQ) | U.S. Copyright Office
any chance you could show a picture of it next to a D4 and D4S for comparison? (or even ROT66? :D)
Picture next to FW3A would be useful too
Hey, TK. how about a pic of fw3a in V’s hand and the e07 in the other? I Might get one for the wifey. I almost had a heart attack when SHE asked ME for a new flashlight because the last one wasn’t bright enough. Congrats on your new lights for a job well done. I think Jacky got the auxiliary LEDs colors right for you!
Maybe next to a ROT66, but probably not a D4/D4S. It seems a bit rude to make a public comparison of two competing clients’ products, especially when both are some of the best on the market.
Also, this is only speculation, but I get the impression that FF may be intentionally avoiding direct overlap, by choosing different form factors and different battery types and different aesthetics. I don’t think the items are meant to be directly comparable. It’s a form of playing nice, and I want to respect that.
Fair enough, I understand your viewpoint and your analysis of their viewpoint. Please show me one of the E07 and the ROT66, if you could! :+1:
Fireflies sent me an E07. Two, actually.
I asked what the purpose was, what they needed me to do with it.
The answer: “No purpose. Anduril designer deserves to own the first one of E07 :laughing: ”
That’s really nice. And well deserved.
a picture next to the rot66 would be nice. and just to verify, the aux leds on the side switch are purple, correct? are the purple leds on the head the same purple as the side switch? are the optics the same size a the rot66, or smaller?
I’m mostly interested in sustained high and effiency.
I guess I’ve too wait for a review too know the sustained high?
Anyway which option is most effecient? Is the light with the most lumens on turbo also the light that’s most effecient at, say, 1000 lumen?
If there is an effiency difference how many percent would that be?
The side switch LEDs look more like cyan on mine.
Anyway, some pictures. My camera doesn’t pick up the aux LED colors very well though. They’re a lot more vibrant than they look in the pictures, and a lot more different from each other. But since the LEDs are narrow-band colors, my camera’s RGB sensor apparently doesn’t know what to do with it.
Also, kind of experimenting with watermarking because it’s getting old seeing my pics used by companies to sell stuff. So I ran a really early proof of concept script on the pics to put some minimal identifying info in them. I’ll have something nicer-looking later.
don’t worry about making your watermarks nicer
make them harder to circumvent or crop out
we appreciate your stuff and don’t mind reading between the lines
TK thanks for the pics. So it seems like the blue/purple can be in differentA orientations
Thanks TK. I agree make it a larger watermark on the product so it can’t simply be cut out, unless you plan to actually sue them.
Those pics show off the color difference between the champagne and desert yellow, first I’ve seen together. I wonder why they didn’t stick with champagne this time.
Is the driver glued? How hard would it be is to reflash it?
There’s already a large watermark on the pics, it’s just very subtle.
TK darker watermarks is my vote. I noticed, but only really notice after I read about it. Just put TK right over there branding?
Interested in throw and beam pattern.
The driver has reflashing pads on the spring side, which should be compatible with Lexel’s flashing key. So it can be reflashed without removing the driver.
But I don’t know if it can be reflashed without removing the aux LEDs. Lexel’s previous designs were all incompatible with the flashing process, so it was necessary to unsolder one of the aux LED board wires before reflashing. That might still be the case, but I won’t find out until I get a suitable flashing key.
My guess is that you’d need to unsolder one of the aux LED wires at the front of the light, then flash the driver, then solder the wire back on. Because the current regulation used on the aux LED board may interfere with the flashing protocol. Same reason why the aux LED board doesn’t have a low mode.
Maybe a lawyer letter pointing out that by using your image (which is automatically copyrighted), they have agreed to send you a baker’s dozen of the flashlight pictured.
Surely there’s a shrinkwrap agreement to be asserted here.
About the watermark thing, I’ll fix it eventually. This was just a quick test to make sure it could be done automatically as a batch using a short script. I don’t actually care enough to do a manual process, like manually adjusting the placement and opacity for each image. So I’ll adjust the input files and parameters to make it just barely visible on a wide variety of images, and probably get some sort of logo to put in the corner.
This quick test was just “use the simplest boldest font on my computer so I can get the script working”.
I was also kind of having fun experimenting with global illumination in order to reduce and soften shadows.
Color turns out well for desert yellow. FF should consider making ROT66 in desert yellow now.
