convoy m1 and m2
It’s similar in concept to the Jaxman M8 throw version : XPL-HI + smooth reflector = compact sized tight hotspot thrower. The previous M1 and M2 were XM-L2 + orange peel reflector = balanced flood and throw.
is AE the only place to get these with the updated driver/firmware?
Very nice upgrade. I will getting a couple.
Ooooo…… I can get a 3000K emitter and a UI that lets me always start in low and eliminate all blinky modes. Heck ya, I need this.
they look the same……? But I am tempted
I don’t have these new XP-L HI versions, but I have both XM-L2 versions. The M2 has a smaller head than the M1, so it’s a little bit more pocketable. Otherwise, I didn’t see any major beam differences between the M1 and M2.
Swap the XP-L HI for an Osram KW CSLNM1.TG and you’ve got a super nice pocket thrower !
My Olight R20 is nearly the same dimensions and I love it with the new White King :sunglasses:
Interesting! The M1 with an HI emitter should throw pretty nicely for a pocketable model.
Hey. If you want a 15% discount use my code DIODEK, it also works with these new models of Convoy M series flashlights. More on this topic Zniżka na latarki i akcesoria Convoy dla czytelników diodek.pl UPDATE 09.12.2019 | Testy ogniw, akumulatorów i sprzętu tech
Or you could use the BLF 15% discount:
This.
Exactly. Both codes will be good :slight_smile:
Just ordered an M1 had a $4 coupon for new users !! $18!
Also the L6 got SMO reflector option with XHP70.2 and output bumped to 4300 lumens. And L2 will get XHP50.2 led and new driver for it.
Hope M1 and M2 has better dust proof than C8+.
My S2+ has good dust seald reflector, but can not say same for C8+.
Thank you for this info!
I’ve been waiting for an L6 with a 70.2 and in clear finish :slight_smile:
I'm tempted to get either the M1 or M2 with the new emitter and the updated firmware. XM-L2 with 3 modes versions were not worth getting since 2015 IMO. Very happy to see these models make a "comeback"
Even with the old XM-L2, an M1 with Biscotti is amazing. I have one and love it to pieces.
Biscotti is more important than the type of LED to me as well! Although it feels "wrong" when an S2+ with XP-L HI out-throws an OP XM-L2 M1 with its larger head.
didnt the m1 have the same nice matt black ano that the L6 had. does look different on this picture.
