From what I know, the problem is probably the substrate.
In normal PCBs, the substrate is FR4 (fiberglass laminate) which is non conductive. It’s just the thin (1oz or 2oz) copper layers on top and bottom which are electrically conductive.
Let’s say you have a FR4-PCB for the LED. You drill the hole, feed the wire trough it and you’re done. There is no real problem as the FR-4 isolates your connection to the flashlight host.
Now for the MCPCB:
Here, the substrate is copper or aluminium. This means, if any part of the wire contacts the MCPCB, it has a short to the body of the flashlight.
The only thing isolation the top copper layer to the thick copper substrate is a pretty thin layer of isolator in between. You want this isolator to be as thin as possible.
You CAN of course add some kind of isolation, but that would increase the cost dramatically. I would guess around 10x the cost of a DTP MCPCB
I think your soldering skills allow using more professional decisions. For example, tiny connectors with small pin located near pcb edge and outer contact soldered to the driver wire.
I would say 100x for mosled X technology.
P.S.
It could be possible, if 2-side alu and copper core board were common, so contact point could be places from the backside and isolated from the host.
I did a fast mockup of how that proposed idea would look.
The problem is, the thin red isolation layer is even smaller in real life. As is the top copper layer. I had to expand them so they are better to see.
We’re talking less than a millimeter.
Now, if just a tiny bit of solder makes a connection down to the substrate copper - you have a short.
1.It doesn't really solve "bump" problem, you still need to put some solder on top,so surface is not flat
2.How easy/hard is to solder wires on big copper PCB with those TH pads?
3.Tolerances of holes for wires in flashlight pills/heads are pretty bad from my experience, TH wire pads would be more sensitive to those tolerances
4.TH wire pad means you have pad also on bottom of PCB, this means you must be very careful not to short them to pill/head - high precision holes are required, and no pcb twisting is allowed
Soldering skills? I hate soldering. Adding pins might work on a triple in your pic, but triples with triple optics don’t have reflector shorting issues, and therefor don’t have the issues that I’m fed up with. I can’t see that adding pins on a “standard” MCPCB would help with reflector shorting issues. You still have to connect the pin to the pad somehow.
If people can drill holes through the MCPCB and do this without shorts, I can’t see the need for such a complicated design. But yes, I admit I know nothing about fabrication methods for LED MCPCBs. If I knew enough about that stuff I would have designed something myself and wouldn’t have needed to spend time whining in here.
Perfectly flat isn’t needed. A little bump would be so much better than the whole wire bent, just like in the thread I linked to.
Don’t know. I don’t see the actual soldering to be any harder. I’m thinking isolated holes with pads on top only.
More sensitive yes, but too sensitive? I guess I haven’t dealt with so many hosts, from my experience tolerances wouldn’t be so bad that this wouldn’t work.
Would you really need that? I’m thinking more of an isolated hole with LED connection pads on top side only. Or simple through holes just like the drilled holes in the thread I linked to, except the drilled holes are actually in the place of two of the standard wire notches, and the LED connection PADs run out to them, using the wire coating as isolation.
Yes… so? I would pay extra for it because it would save me headaches. People have spent a various amount of time dealing with reflector shorts and ways to get around them like in that thread. I’d just be happy to pay extra to avoid it… but as I can’t find any MCPCBs like this, I guess I’m alone.
Dont know anything about most modern modules. Some time ago pcb was made from 3 layers - aluminium base + best possible isolator + top thin pcb. First modules had copper insert (thin coin with 3 central pads growing) and top layer had holes for this pads.
P.S. Please dont try to repeat lux-rc technics. They are not budget and usually require a lab equipped as good as it is needed to win Nobel prize in physics.
As for repeating their ideas: Thanks for the warning. I view myself as experienced enough to know what is a good idea and what is just a pain in the rear. (ECE education + >5 yr electronics + embedded systems experience)
Pins can be located at thin edge - solder bubble is usually much bigger and way more close to the center.
Pins can be angled - i.e. you can move connection outside the pcb border.
Pins can have isolated base.
If pcb diameter is too small and reflector base is too big, I see only one decision. You extra thin pcb, soldered with hot air face to face to main pcb. In most cases it can be little bigger than stock pcb. Also you can use flat metal strips with thin heatsink instead of wires (power tool batteries can carry 10amps trough nickel strips but I think copper is better).
Pins might be a great suggestion, but where are the single LED MCPCBs with pins? If they exist I’d love to try them, if not, then it’s back to modding. How would you suggest adding these pins to single LED MCPCBs?
I’ve been filing down reflector edges and using kapton tape. It works but it’s ugly. I guess flat copper straps could work too but holes are a much nicer solution so if I have to do it myself I prefer to drill holes. It just would be nice to not even have to do that.
Success at adding pins or soldering wires to MCPCBs? I have a normal soldering station and tweezers. Sure, I can solder wires to MCPCBs, but still have to file down reflector if it’s too big.
Still interested in Kiriba-ru’s pin solution for single LED MCPCBs. Care to share?
Edit: This is thread hijack… I’ll start this discussion elsewhere. I can at least gather from here that there won’t be any Led4Power MCPCBs with holes.
I would like to purchase some of your product to make my flashlight, but i’m not sure which to buy. What is the main difference between LD-B4 and LD-A4, and which driver are compatible with which of your LED PCB? Is it correct that B4 driver need MOSFET MCPCB, but A4 do not? Thank you.
New 3030 DTP boards in 16mm and 20mm size, made specially for Osram white flat LEDs, but Osram has some other high power LEDs in that size too.
Reason for these boards over XP/3535 boards is that with XP boards white flat LED like to slide on one corner during reflow causing off-centered LED if it's not re-centered during reflow with tweezers.
For small qty this may be ok, but for me it was a PITA. With new 3030 boards there is no such problem since footprint is exact like it should be and LED is always nicely centered.
These PCBs have factory lapped bottom surface and they are fully gold plated, so price is little bit higher than nickel plated PCBs. Also PCBs in panel are separated by double V-cut for nicer and cleaner cut without notches, this also adds ~10-15% cost.
From now on I will only have white flat LEDs soldered on 3030 PCBs, I already changed listing for 20mm white flat 1 and 2, and will do the same for 16mm after few last pcs soldered on XP16 PCBs are sold.
