Not sure what your referring to. But I believe a Xhp50 or Xhp70 in single High mode in this light should fit the definition of pocket rocket. (Or do you mean, the flashlights actual size?)
You must be kidding about a S2+ would be brighter, rocket wise than a Xhp50.2 in this light.
I have a S2+ in XP-L Hi and its meh, not impressive, it okay for a newbe starter light.
Some of you didn’t read past the title, that’s funny. I added the a summary in the title for those of you that also drive a vehicle and don’t look past the steering wheel.
To turn this into a “pocket” rocket, I guess it will imply some changes, namely to get a good brass pill, eventually!!
The flashlight has the looks, but I don’t know if it has the “inners” to turn into a rocket!
The Convoy S8 has similar look, but seems to be more reliable than this (not related to being Ultrafire or not)!
Wellp, some UF lights make fine hosts (eg, C8, ’502, etc.), but only if “real” UF (used to be, the Great Copier UF became the most copied, too).
Doesn’t matter if you have a DD light that can belch out 2000lm ’til the LED turns blue, it’ll heat up like the business end of a curling iron in no time, and be rather uncomfortable to hold without oven-mitts.
So, you can make virtually anything a “pocket rocket”, but it doesn’t mean it’s a Good Idea.
That said, if the light has a good thermal path, sure, you can fit it with an XHPwhatever and DD/FET driver and let it cook… for a short time. Hence the oft-lamented characteristics of stock lights with timed turn-down, to keep the light from self-immolating.
Still, if you want a wow-factor, to be able to light up an entire valley for a short time, there’s no reason not to. Intense pain and the smell of frying bacon will let you know when it’s time to flick it off turbo.
Real UFs can be pretty good… as hosts. Yeah, they tend to CW and blinky drivers and the like, but you can replace the goodies with better ones and have a quite-nice light.
Oh, a ’502 was my EDC for æons, with a 1-mode (think it was) 1.4A driver, and was/is in perfect condition. Not even a hint of “scratchiness” or flicker from the stock switch, no chips/nicks/wearing in the ano, nothing like that.
The DV-S2 is a really nice magswitch diving light that’s been dive-tested by some folks here, and holds up nicely.
I wouldn’t knee-jerk any poo-poo reaction to the UF name, not for legit UF lights.
