Guarantee: You’ll be shocked with their prices for the quality of the light you get.
I would like the SST-20 5000K code please.
May I have the code please ,thanks
sent guys
I saw ” If you want to use 21700 battery,pls choose the option 21700 ” is it mean they have 2 body tube to choose ?
May I have the code for SST-20 5000k
Thank you
May I have the code please?
product link:
Code to apply: ndns22
Purchased SST-20 5k.
Thank you
Where do I enter the code?
Code for XHP50.2 5000K please
product link:
Are the SST20 3000k and 4000k 95CRI or regular? Thanks.
SST-20s 4000k and below CCTs are only available in 95CRI.
It’s only rear switch?
Just placed an order for the SST20 3000k. Nightwatch makes great host. They have good finning and enough mass to handle high output like a champ. I might swap in a White Flat on this one since the max current is 5A for this.
tatasal would you please check is it available option 21700 as in the product detail
// If you want to use 21700 battery,pls choose the option 21700 //
thanks
Ok, l will check.
Edit: Dec. 12
In the drop-down selection for led tints, at the bottom of the list of led tints is the $3 21700 tube.
Any idea when these will start shipping?
