[BLF special edition light] new Sofirn AAA twisty high CRI Yuji 5mm LED (CCT 3200K or 5600K) for 6.50 USD
2863 posts / 0 new
slowtechstef
slowtechstef's picture
Last seen: 1 day 20 hours ago
cyclops wrote:
The tailcap design on the C01 is awesome! I will have to get a magnet for it once I figure out the size needed..
Magnet size: diameter 5mm; height of magnet 3mm. Also see the C01 specifications page.
N52 is the highest magnetic strength available.
I found 5×3mm size magnets in N52 strength on BangGood.com and in N50 strength on FastTech.com.
Edit: I added the links to several products pages for tritium vials and magnets with the right sizes to the C01 specifications post.
defloyd77
Last seen: 1 week 15 hours ago
I wonder if there’s a magnet that’s the size of the tritium slot for those of us who want MORE POWER!!!
slowtechstef
For the sake of safety: for anyone with young children (age < 6 years), please be very carefull with these little rare-earth magnets, and carefully store them out of reach in childproof closed containers. If your child swallows more than 1 magnet, this can cause serious tissue damage and possibly even cause death. For example see this.
defloyd77
Great point. Animals as well.
MascaratumB
MascaratumB's picture
Last seen: 8 min 36 sec ago
My last update was on 28th November, showing it is/was in Guangzhou (International dispatch).
As we’ve been having some strikes in Portugal (customs and stevedore), I am not sure if the delay has to do with that or with the shipping process in China.
My purchase protection will end in 23 days…I hope the flashlights arrive here before that… Oops
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
djozz
djozz's picture
Last seen: 4 sec ago
A fix while it ain’t broken.
A possible failure point of the production C01 is that the contact flats on the driver that get twisted against the battery tube actually have very little contact area, less than the prototype because the brass is not extended fully to the very edge of the circuit board. It is one of these things that chinese manufacturers change without notice while unaware of the consequences.
So also because this afternoon I found a little piece of 0.1mm brass foil in my metal goodies drawer, I did this fix:
1) scraped away some more solder mask
2) cut two pieces of brass sheet to size, and tinned both the driver and the brass flakes with solder
3) soldered the brass pieces in place, as flat as possible squeezing excess solder out.
4) sanding away excess solder
5) after 50 or so twisting actions you can see where the contact area is now, it has more than doubled compared to stock, and the .1mm of brass takes very long to wear through.
slowtechstef
Bad news, and good news.
1. I managed to kill a Sofirn C01 by applying a lot of heat with a paint stripper to it. Facepalm
2. The potting with thermal epoxy fills the complete cavity surrounding the PCB and LED. Thumbs Up
When I tried to remove the PCB with a sharp knive from its housing, the PCB got separated from the thermal epoxy. You can also see how the coil broke of. The Yuji LED was killed as well Crying
The driver below is the PCB of a Gerber Infinity Ultra. In the upper left corner you can see Gerber only selectively applied conformal coating to the coil (yellow blob).
Edit 1: perhaps I should offer testing services to flashlight companies to see if their products are FOOLPROOF FULLPROOF. First I managed to break the pocket clips of the C01 prototype, and this time I completely killed a C01…
Edit 2: For anyone wondering about my obsession with stuff that is robust, there might be a relation with this post Innocent
hank
hank's picture
Last seen: 19 hours 14 min ago
Thanks for catching that, and documenting how to fix it.
I noticed another corner cut. After half a day in my pocket with keys and change, the black paint is flaking off the pocket clip and the tailcap. There’s visible rust on the metal of the pocket clip where the paint flaked off, looks like it was painted without prepping the metal.
I wonder sometimes how China’s going to survive the next century, if all their civil and military manufacturing is done to the same don’t-give-a-damn carelesness about specification. Things fall apart when they’re built in slapdash fashion. How long does it take to learn that?
Quote:
“My time in China has taught me the pleasure and value of craftsmanship, simply because it’s so rare. To see somebody doing a job well, not just for its own reward, but for the satisfaction of good work, thrills my heart …. the prevailing attitude is chabuduo, or ‘close enough’. It’s a phrase you’ll hear with grating regularity, one that speaks to a job 70 per cent done, a plan sketched out but never completed, a gauge unchecked or a socket put in the wrong size. Chabuduo is the corrosive opposite of the impulse towards craftmanship”
https://aeon.co/essays/what-chinese-corner-cutting-reveals-about-modernity
As the old saying goes:
Good, cheap, fast — you pick which two.
Or maybe pick which one ….
https://www.google.com/search?client=firefox-b-1-ab&q=chinese+%22close+e...
But I still like the flashlight so far. As U. Utah Phillips says in his story: It’s good though.
Better than I could make myself.
peabody
Last seen: 16 hours 27 min ago
Tracking just put my package in Chicago.
Kona G
Last seen: 7 months 4 weeks ago
Hank, and here i thought my light paint peeled off due to our gov irradition of packages from Asia lol. Closer examination does show metal in rusted condition! Clip is in garbage can, light will soon to follow!
Streamer
Streamer's picture
Last seen: 3 months 4 days ago
edit:
I just can’t imagine anybody having to solder on brass foil contacts for inadequate factory ones. Crazy Is the C01 turning out to be a POS (less than adequate) before it even debuts Question
djozz
djozz's picture
Streamer wrote:
I just can’t imagine anybody having to solder on brass foil contacts for inadequate factory oness. Crazy Is the C01 turning out to be a POS before it even debuts Question
This is a very hard question to answer, with my mod I anticipated on a potential problem in the future. It is by no means sure if this problem will occur and when.
Btw, calling this light a POS because of this would not be my style. But time will tell if this will become a problem.
Streamer
Streamer's picture
If it ain’t broke…don’t fix it. Let the new released torch cut its teeth without interference. It needs to be seen what it is not what it can be made to be. So far, it’s chasing the ghost of the Fenix E01. I ordered C01’s just like everybody else in thread did. Give it a chance as is from Sofirn.
dealgrabber2002
Last seen: 1 day 13 hours ago
Received mine today. Great light but not much people mention that it has a tunnel vision beam, no spills. Like a zoomie profile.
Maybe everyone knows but me. Lol
Streamer
Streamer's picture
edit:
BTW…I wan’t calling it a POS (less than adequate)…I was asking if it was turning out to be a POS (less than adequate)….all directly from your input djozz.
Let’s hope not so. Thumbs Up
Micmania
Micmania's picture
my two C01’s arrived … Thumbs Up
Lim_Wee_Huat
Not even a single speck of worries here.. Excluding the 4 submitted in the interest list, so far I’ve ordered another 8 because this specfic model is the perfect startup high CRI light for my loved ones as coming festive gifts..:) It’s within my budget.Using this to educate and get them started with. Many thanks for those and Sofirn who made this happen..:) High CRI ftw!
hank
hank's picture
no, no, send it to me instead of tossing it, if you’re not kidding.
Like I said, “moose turd pie” is better than what I could make myself. So I like it.
If anything, this should be a learning experience for Sofirn about meeting specs, not changing specs, and checking every piece they get from subcontractors for qa/qc.
And making sure to have a qa/qc program, of course. Those are defined terms and if Sofirn learns to adopt a quality production process they will stand out markedly different from the average manufacturer in industries around them.
I ranted about this in an earlier thread:
http://budgetlightforum.com/comment/704501#comment-704501
http://budgetlightforum.com/comment/704556#comment-704556
Quote:
Personally, I think China needs something the USA had for a while and lost — unions. They weren’t/aren’t near perfect. But training and competence rested with the workers decades ago. “Union Made” on something you bought said the workers who made the thing likely knew what they were doing.
That’s why I asked who owns Sofirn, a while back. If the workers own it, well, pride’s something that develops.
If outsiders own it, that’s less likely.
pinecone
pinecone's picture
Last seen: 1 year 1 month ago
GreenLights wrote:
I ordered on the 10th as well. Ali, USPS, and ParcelsApp all have the last update on November 24, 2018, 11:05 am:
Processed Through Facility
GUANGZHOU EMS, CHINA Sad
Ordered on the 28th, 10 days later and this update:
December 8, 2018
jon_slider
jon_slider's picture
Last seen: 2 min 58 sec ago
Im a bit lost
was unable to find the photo of the fenix contact area, I know its here somewhere..
found these..
but still dont know what that last pic is, and what the production contacts look like, before being sanded and soldered over..
djozz wrote:
The 3200K C01 sample…
not sure if this is just art:
djozz wrote:
can someone give me a pictorial sequence.. Fenix contacts, and Sofirn current production contacts, unmodified?
hank
hank's picture
When I look down the battery tube past the threads, I see a shiny metal shelf — I assume that’s what the contacts on the head are supposed to reach. Maybe a dab of conductive lube would keep the contacts from wearing out.
An interesting parallel — one design problem of the Arc AAA was that the circuit board was held to the head by a metal collar just crimped tight that eventually loosened up or flaked off due to metal fatigue. Arc covered that under warranty for the owner’s lifetime; I’ve had several fixed over the years.
But ya know, there’s an argument in favor of using a threaded retaining ring to hold the bits in place.
cyclops
Last seen: 4 days 1 hour ago
I received mine yesterday and this is how it looks like –
jon_slider
thanks
here is my Fenix E01
now, what is the problem?
teacher
teacher's picture
jon_slider wrote:
thanks
Good question. I’m kinda lost myself… Question
Streamer had a legitimate question too about it being a dud from the beginning.
But, from reading it all several timesFacepalm …. my take is this:
“I think” djozz was identifying/speculating what ‘might’ be a weak spot in the unit and could possibly cause problems sometime in the future.
He then illustrated a ‘fix’ that would correct the problem ‘should’ it occur.
The same ‘fix’ would prevent it from happening in the first place.
Anyway…. that is my take on it. There is no problem at this point. … Big Smile
djozz
djozz's picture
This issue needs a good pic I see now.
Left my Fenix E01. You can see that the copper is extending to the edge and that the contact area is ok, not great IMO but this light has proven over the years that it is adequate.
Middle is one of the C01 prototypes. I see now that the copper here also does not extend to the side, but that the contact area is only good because the circuitry is not overly well centered on the board, so that one side makes for a very good contact area, the other side much less. Btw, at the time of the prototype I did warn Barry to pay attention to good contact points.
Right is the production C01. The circuitry is even a bit further from the edge of the board compared to the prototype, not much of a contact area leftover.
But it works and maybe for a very long time, again mind that there is no hard data at all at this moment that this is a failure point at all, we are speculating based on what we see. It will not help for this production run but I will confront Barry with this picture.
(in the picture not all boards seem the same size, this is distortion of my phone camera, in reality the boards are all the same size)
slowtechstef
Great picture djozz, that clearly illustrates the issue.
I was wondering if there is a simple, cheap alteration to the head design Sofirn could implement in production in order to make the contact areas between PCB and body tube more robust and reliable?
Would just moving the contact pads more outside or enlarging them outwards be enough, or would an alternative design be a better fix (e.g. solder on a thin brass ring on the PCB)?
viblet
Last seen: 8 months 1 week ago
I like to have one of this in my collection Smile
slowtechstef
Am I correct that the red encircled areas are the contact areas?
slowtechstef
It would be great if we could come up with a design for the contact areas that would make the C01 as reliable as an HDS, without its complexity or high price tag.
Picture shows a vintage HDS EDC Ultimate 60 (2004-2006).
teacher
teacher's picture
Thank for explaining THIS further djozz. Thumbs Up
Glad you cautioned them about this in advance, a shame they apparently ignored you.
