Must see.
Where did you get them?
Must see.
Hmm. What is the V2 vs the V??
Think it’s smaller
Beamshot, though I don’t feel that it does justice to the Luxeon V2
Left to right: Convoy M1 with 70CRI XP-L 5000K, UltraTac A1 with 90CRI 219B (I thought 4000K but maybe not), Convoy S2 smo with Luxeon V2 70CRI 4000K, Wuben E05 with 90CRI XP-L2 80CRI.
Here’s another between the Luxeon V2 and the XP-L2 4000K 90CRI:
So is it a different LED than the V or is it the same but with a 3535 footprint?
It seems to be quite similar, but perhaps not the same. I’m anxiously awaiting proper tests. Anyone care to volunteer? Djozz? Texas Ace? Koef3? Maukka? I’d probably donate some if there’s interest.
Thanks, I like it also. Not sure about this “Wuben E05 with 90CRI XP-L2 80CRI”
I would be interested in seeing someone test this too.
XP-L2 can work well with a frosted or pebbled TIR though.
Thanks.
So it has a smaller die: V2 = 2mm² and V = 4mm²
Luxeon V has 4mm2 die, V2 has 2mm2 die.
Agree, not sure I was able to explain it well but glad you had similar results.
This LED should compete with any 70 CRI LED out there and has a good balance of output, tint and uniformity with a good price.
Quite a few 2 mm² LEDs in 3535 factor showed up recently…
Nice!
It’s flip chip, right? Does it have any throw?
Yeah, I think its a flip chip:
Comparing two Convoy S2’s side by side; one with LH351D and one with Luxeon V2, the throw of the Luxeon V2 kills the LH351D. But that doesn’t take much, the LH351D is a very floody LED.
I’ve had a lux meter (UNI-T UT383BT) for about a year, but had never taken it out of it’s package until today. I tested just a couple lights before running out the door this morning, and unfortunately I didn’t have quick access to the Convoy S2 with LH351D in order to get numbers on that; hopefully I can tonight. Here’s the 3 I was able to test (so you have something to compare against in case my numbers are skewed):
Do those numbers sound right? Since these aren’t real throwers (perhaps with the exception of the C8), should I measure at 3m (or even 1m) instead of 5m?
Without being scientific it does appear to have more throw than a LH351D but with the dome on I don’t think anyone would consider this a thrower. Not sure how it performs dedomed and I think thus far only gchart and I have even tried them in a flashlight.
I have a C8F with 3x Luxeon V and when I compare it next to a LH351D of the same type there isn’t a huge difference in the overall beam. It’s a more intense hotspot but not by a huge amount.
If I’ve got time tonight I’ll try getting side-by-side numbers with the same flashlight setup using Luxeon V2, LH351D, XP-L, and XP-L2. I’ll see what else I can scare up, maybe a XP-G2, XP-G3, SST-20, XP-L HI. I’m pretty sure I’ve got all of those on hand, it’s just how much time I’ve got to swap in and out a bunch of different LEDs.
Here’s a mechanical comparison of the domes of the SST-20 and Luxeon V2. SST-20 is quite a bit smaller in all dimensions and LH351D is slightly larger in all dimensions.
I suspect this wont be too helpful but I measured two C8F’s at 380mAh (1x7135)
LH351D 4000K 90CRI
131 lux
Luxeon V2 4000K 70CRI
268 lux
Measured at maybe ~15ft
Wow. Having 1/2 the die size REALLY helps with throws.
Then again, the LH351D is a 90CRI emitter, so the results aren’t TOO accurate, but are representative of real life.
