(Cancelled)D1S+, CSLNM1.TG LED, 850lm, 320kcd
For sure will buy one. Also would like to buy centering ring and driver separately too.
What chromacity bin and flux bin is this emitter? Will you be selling these on your website?
As a suggestion, I would love to see a 21700 usb rechargeable version. Some of my less hardcore friends won’t buy unless it has built-in recharge.
I would be more than interested in a centering ring + driver kit.
interested
Definitely interested
Tried this led with D1. It simply doesn’t have good enough reflector. It top half and bottom half has a little different focal point whith doesn’t matter with larger led like XP-L HI. I played with focusing for hours.
It can’t get any better than this.
Yeah, i get the same impression…
And then you still need a topped up cell at 4.2 Volts to get maximum output…
Linear FET CC driver shouldn’t be much more expensive though…
Interested :+1:
Thank you for this, might of saved me some money and time.
Interested
The D1S is good BTW. Much better reflector than GT mini.
Interested.
Judging by the picture, it seems the LED sits too far forward relative to the reflector.
I can see the beam get narrow half way and then get wider again.
Looks like you should try some extra shim between reflector and LED board.
interested
Just when I am about to order a d1s now I see this. I will definitely wait for this version.
Yes , I have all the others , so I gotta have this one !
Trust me I tried everything. :slight_smile:
If I move reflector up then the beam starting to get parallel-ish but the corona starting immediately getting huge amd brighter and the hot spot also getting bigger and dimmer. Like the reflector has two parabolic curve.
I can’t explain it better. Maybe with this image help. This is with XP-L HI. The edge of reflector and the area around close to the led is in focus. But If I go farther the white area getting yellow and the yellow area near led getting white. With white flat it is more noticable.
Interested
Yeah, i believe you.
It just looked like that in the picture.
Hmmm… Doesn’t look like it should…
Any anomaly in the optics will become very noticeable with this Flat White 1mm².
I have the same problem with a narrow beam TIR optic i wanted to use for the White Flat 1mm².
Seemed to work well with dedomed XM-L2 but it’s a messy compromise at best with this little LED…
I also wasted a lot of time on trying to get it right…
I would have expected a better reflector in your Emisar though.
Interested.
