Did you build a rig for this purpose?
Any pics?
I did build something like this before, but I used bypassed spring holders instead of brass buttons. That was very hard to do though, unlike the more refined method I presented to you guys.
However, now that I have made my Beryllium copper springs, I am going to do one that is much simpler to do for everybody, and is much easier to set up.
Awesome. I’d like to make one. But since you know what you’re doing I’ll wait to see how you did it.
When you decide to use your new springs to build your new tester, it won't test IR the same as the SM8124A will it, but instead the second method you mentioned above to give real IR readings?
I have doubts about this device.
I need to do some tests using the DC Calculation method to verify but I’m getting results that aren’t consistent.
That said, I removed the cable separator because the leads were too short to get to both sides of my batteries.
Does anyone know if there is some magic in that simple plastic separator that could affect the readings?
Today, I tested some new cells with my SM8124A. This is the impedance I measured:
Format | Name | Impedance (mΩ) |
21700 | Samsung 30T | 6.0 |
21700 | Samsung 40T | 7.4 |
21700 | Samsung 50E | 22.0 |
21700 | Sofirn 4.000mAh | 13.6 |
20700 | Acebeam 4.250mAh | 21.6 |
18650 | Sony VTC6 | 11.8 |
18650 | Samsung 25R | 12.2 |
18650 | Samsung 30Q | 12.5 |
18650 | Imalent MRB186-P30 | 19.3 |
18650 | Wuben 2.600mAh | 23.4 |
18650 | Sofirn 2.600mAh | 41.9 |
18650 | Sofirn 3.000mAh | 45.2 |
18650 | Xanes 2.600mAh | 45.3 |
Thanks for sharing! That would be a useful baseline reference.
I only have a few of those batteries from your list. I don't have the SM8124A, but instead got the YR1030. I wonder how different the measurements taken by the SM8124A compared to the YR1030...
Nice chart thanks. My Samsung 30Q from Illumn read 10 and 30Q from Banggood read 12 so close enough.
FWIW, it takes a lot of patience and two calm hands to get useful values with the SM8124A.
Especially, with button top batteries it’s quite a nightmare to align the probe correctly in order to get useful information.
I guess it’s the same with the YR1030 from Vapcell. They had it for a very decent price on Black Friday. Unfortunately, I forgot to buy one as I would have liked to verify my values with a second device.
Major PITA to align the probes on button tops. I use my desk lamp with the magnifying glass otherwise it takes too long.
LOL…“PITA”…that’s exactly what it feels like.
Later on, I try to amend my chart with values I took from my 26650s (Shockli 5.500mhAh, Keeppower 6.000mAh, Dolidada Fake PLB-55-As, Thrunite 5.000mAh, etc.).
I have now added some more batteries. All cells were measured in new, unused condition. However, the 26650 cells I bought had some differences between them.
Format | Name | Type | PCB | Impedance (mΩ) |
21700 | Samsung 30T | FT | 6.0 | |
21700 | Samsung 40T | FT | 7.4 | |
21700 | Sofirn 4.000mAh | FT | 13.6 | |
21700 | Efest 5.000mAh | FT | 20.6 | |
21700 | Samsung 50E | FT | 22.0 | |
21700 | Acebeam 5.000mAh | BT | x | 30.4 |
20700 | Acebeam 4.250mAh | BT | x | 21.6 |
26650 | Shockli 5.500mAh | FT | 12.5 - 12.6 | |
26650 | Shockli 5.500mAh | BT | 12.7 - 13.0 | |
26650 | Keeppower 6.000mAh | FT | 16.4 - 17.5 | |
26650 | Keeppower 6.000mAh | FT | x | 31.5 - 33.2 |
18650 | Sony VTC6 | FT | 11.8 | |
18650 | Samsung 25R | FT | 12.2 | |
18650 | Samsung 30Q | FT | 12.5 | |
18650 | Imalent MRB186-P30 | BT | x | 19.3 |
18650 | Wuben 2.600mAh | FT | 23.4 | |
18650 | Sofirn 2.600mAh | BT | x | 41.9 |
18650 | Sofirn 3.000mAh | BT | x | 45.2 |
18650 | Xanes 2.600mAh | BT | x | 45.3 |
Here's my list so far. Need to find the data sheet but I think the 30Q's from ff are out of spec!
Yeah. That Illumn cell is either a beast, or something is wrong.
I don’t think the FF cell is bad though. The maximum internal resistance of a 30Q with AC testing is 26mOhms.
Thanks, saves me looking for the sheet! Tested all the illumn 30Q's too many times and always 9.
Thanks for mentioning that 30Qs from Fireflies.
I also got 3pcs 30Qs bundled with the Fireflies ROT66 (I am unable to purchase 30Qs without flashlights [bare batteries from any foreign online store cannot ship to my country, except if inside a flashlight], so all my 30Qs are only purchased when I purchase a flashlight, either the “BLF A6+30Q” or the “S42+30Q” bundle from BG).
The 30Qs I got from BG have lower IR than the 30Q I got from Fireflies… Will do some measurements again. Forgot the figures but there are noticeably higher IR, measured either using the MC3000’s IR test or with the YR1030 battery resistance tester.
I think it was mentioned somewhere before that battery manufacturers use the AC method to grade the cells and then sort them depending on the results. It seems there may be A-B-C and possibly even D grade cells of the same make that are then sold off accordingly.
Update (see highlighted in red).
I am pretty much amazed about the extreme low impedance of the Tesla cell (Sanyo NCR21700A 5.000mAh 15A).
21700 | Sanyo NCR21700A ("Tesla") | FT | 11.2 | |
21700 | Sofirn 4.000mAh (w ring) |
FT | 13.5 | |
21700 | Sofirn 4.000mAh (w/o ring) |
FT | 13.6 | |
18650 | JetBeam HR26 2.600mAh | BT | x | 16.5 |
Obviously, Sofirn rewraps cells of different manufacturers as can be seen on my comparison of two Sofirn 21700 4.000mAh batteries. Both batteries were part of two C8F 21700 flashlights. The one with the recessed ring in the bottom seems to be a Lishen 2170SA. Fortunately, both the one with ring and the one without seem to have similar specs in terms of capacity and performance.
Updated my list with legit Samsung 40T's that I got today. Inserted them in my two E07's and they shine seriously bright.
I'm also looking for my first tester. I choose between YR1035+, SM8124A, Volcraft BT-501 - which is better ?
