Where do I enter the code?
Code for XHP50.2 5000K please
product link:
Code to apply: ndns22
Are the SST20 3000k and 4000k 95CRI or regular? Thanks.
SST-20s 4000k and below CCTs are only available in 95CRI.
It’s only rear switch?
Just placed an order for the SST20 3000k. Nightwatch makes great host. They have good finning and enough mass to handle high output like a champ. I might swap in a White Flat on this one since the max current is 5A for this.
tatasal would you please check is it available option 21700 as in the product detail
// If you want to use 21700 battery,pls choose the option 21700 //
thanks
Ok, l will check.
Edit: Dec. 12
In the drop-down selection for led tints, at the bottom of the list of led tints is the $3 21700 tube.
Any idea when these will start shipping?
Do you have the runtimes on high and turbo?
This Sunday.
Edit: All unshipped orders will be shipped out today, Friday.
NS22 SST20 3000k:
Ordered SST20 6500k
Thanks
Wow. Simply put, that is impressive throw for a 3000k 95CRI emitter.
Do you have a beamshot for the 4000k version? It would be awesome if you could take/have one.
anyone knows how this compares to the Astrolux C8? I know i can see at least 560m with the Astrolux with room for a little further
tatasal, howcome I don’t see that gray color option. I was thinking about replacing the emitter with the White Flat but seeing that beamshot with the 3000k SST-20, which is what I ordered, it’s making it a hard decision.
Also interested in a gray color, where are the options?
I’ve put a 95 CRI SST-20 in two different lights that originally had an XP-L HI. One was regulated, and the throw was the same. The other, an Astrolux SS has a FET driver, and both power consumption and throw increased. I get 434m (47 kcd). This light has a larger head and reflector, so I’d expect more throw.
1250lm is a fair bit more than I get from 5A, so I imagine those numbers are for low-CRI. I’d expect over 1000 lumens and over 500m from high-CRI though.
What sort of driver do the 3 volt versions use?
BLF A6, nw: ————————————————————————————— NIGHTWATCH Seeker NS22 3000k, 95cri:
The NS22 below the BLF A6:
