Hey Hank, I really like how you jump on the latest greatest thrower LED. It can really make your products so much better than what you’ve shown is a good example.
But please let me join others with the question:
Is the driver going to be regulated?
Many of BLFers are savvy enough to use only weak cells with FET+white flate combo. But we’re an exception….you could artificially increase resistance in your host, but that would be a hack rather than a solution.
Thanks a lot for the info.
I wanted to do the same to mine.
GT Mini, D1…some good lights that turn out to have too poor reflectors for that LED.
And actually both have been my white flat candidates.
It may not be so simple….
That’s how thickly anodized undyed alu looks like:
That’s a different alloy and different thickness, but how thin would ano have to be to produce practically no colour change?
Agro, a lot of the industry doesn’t like change, they’re used to hiding imperfections behind sandblasting. To take the parts straight from the CNC to the ano bath will show the machine marks from the tooling and while some of us like that the industry is afraid it will be seen as ugly or unfinished by the consumer market at large. So on the few occasions we have had success it has been in limited runs. I’m ok with that, a serial numbered limited run of 100, or 300, would be great. If they saw a quick sell out then they might be interested in taking it further, maybe a second run of 500 or 1000, who knows…
Very much interested as well, but also interested in exactly how the 5 amps restriction is implemented. Regulated would give you 5 amps pretty exactly, but using a FET, you can restrict it to 5A max based on the best fully charged cell with adding the right amount of resistance - very different solutions.
