Interested
any specs regarding lumens?
Its in the titel of this thread: 850lm
Verry interested!
Agro, I have lights that this is successfully done on… wouldn’t have asked if it weren’t possible. Heck, I’ve done it to parts myself.
interested
Good to know.
I believe we asked several manufacturers to do that already and nobody agreed.
Any idea why is it so?
Interested.
I’ll get one for sure.
Vinh from skylumen tested the CSLNM1.TG LED in the D4S and got 3,000 lumen with 126,000cd @turn on, please use this LED in your D4S!
Agro, a lot of the industry doesn’t like change, they’re used to hiding imperfections behind sandblasting. To take the parts straight from the CNC to the ano bath will show the machine marks from the tooling and while some of us like that the industry is afraid it will be seen as ugly or unfinished by the consumer market at large. So on the few occasions we have had success it has been in limited runs. I’m ok with that, a serial numbered limited run of 100, or 300, would be great. If they saw a quick sell out then they might be interested in taking it further, maybe a second run of 500 or 1000, who knows…
Very much interested as well, but also interested in exactly how the 5 amps restriction is implemented. Regulated would give you 5 amps pretty exactly, but using a FET, you can restrict it to 5A max based on the best fully charged cell with adding the right amount of resistance - very different solutions.
Interest intensifies!
I am interessted for a whole flashlight.
Most definitely purchasing one. Can’t have enough mini throwers to lend out, Maybe I’ll keep this one for self and lend the D1s more.
I would get both D1S and D4S with this new emitter but only if you make a 21700 version.
INTERESTED
Interested
How this gasket work?
Is not close to led.
And same for xp-l and white flat?
Interested!
Thanks Hank
