Yeah she was probably wrong in the color temp department.
It’s funny though that we got a warmer tint bin with a higher flux bin. That was surprising.
Edit: I was the one who was wrong. Transcribed badly on my part.
BlueSwordM, thank you so much for taking the initiative on this! If this works out, we are truly in your debt.
^ . :+1:
2 weeks ago when ToyKepper proposed 3 choices, the deal was to wait for a better (rosier) tin bin T1, T2, T3, T4. It was not to wait for the greenish T6. :weary:
Thank you for doing the legwork!
Interested in 2x lh351d 4000k.
I also would prefer below the BBL, but I’m being open-minded because I know some people have stronger feelings about color temperature than I have about small positive Duv values.
What encourages me most about Maukka’s testing of LH351D’s with a similar or worse Duv than a T6 should have is he saw limited tint-shift across the beam in a Carclo optic. Find a rainbow beam more distracting than slight deviations from the BBL.
Yeah its very green corona/hotspot that is the worst. I can stand above BBL if it’s consistent across the beam (and the CCT doesn’t shift too much either).
I’ve been pretty happy with the 4000K LH351Ds I got from Mtn-Elec that I put in my Q8. Don’t have any idea what tint bin they are but less green than a lot of Cree emitters I’ve seen that weren’t specifically binned for on/below BBL.
I think it would be useful if you asked to be removed from the TLF list.
Yeah, it’s kind of important to be as accurate as possible about the lists. I don’t expect to reach 100% accuracy, but some past projects have gotten as high as ~95%.
The list in TLF was updated at last in September 20th.!
Guys, I came back for an important exception.
I just received a critical email from Digieky stating there was an error in communication about the chromacity bins.
While the T4 bins are available from Samsung, they are not available from Digikey at the time!
The rep stated that it was an error on her part stating a typo, and that the T4 bin is only available on a custom order :cry:
Only the T6 bin are available and in stock from Digikey :frowning:
Sorry :cry: :cry: :cry:
is the design of the light final ?
Yes… pretty much.
Please sign me up for two FW3As - one of each emitter type.
Can I be added to the list for a second one. Total of 2.
Been trying to resist but I don’t think I can pick which emitter I’d rather have.
In for 2
In for one with the lh351d emitter
Not found myself so
Interested in one LH351D 4000K 90CRI
thanks
I see you at #1695.
