Looking forward to this one! Fresh tech and new implementation, is always exciting.
I also need to correct The Driver, the BFF is definitely not 250Mcd. There is a reason I have said it start with a 1.
If you want you can calculate what equilibrium temperature the crystal would reach if it was in water.
I can tell you right now that 18mm^2 of area will reach a very high temperature before 3W of heat are carried away by the water…
Also rotating phosphor is what many projectors use:
Doing this with a single crystal phosphor would cost tens of thousands of dollars, assuming you can get a piece that large.
Thanks
I’m still waiting for more updates on yours!
Suggestion, wear an eyepatch over your best eye whilst working on this. And please don’t shine it in my direction.
No worries, update is coming, just been busy with some other stuff.
You need to use two ar-coated (specifically for 450nm) cylinder optics together with a G7 focussing optic to get the best possible hotspot, highest efficiency and least amount of stray light. The cylinder lenses correct for the differently expanding axes of the rectangular laser beam. This can easily cost 100$, but it’s worth it.
The optical assembly and the cooling will probably give you the most grief.
Did you get a suitable, adjustable laser driver? I know a very compact one if you need it.
The engraving lasers they sell are doing .1mm^2 without any cylindrical optics, so I’m going to try that first.
There’s no point in spending $450 on an acylindrical lens if I’m already burning through the crystals without it.
The driver I bought can be regulated by 5v in addition to a current trim pot to adjust the maximum.
Also comes with a temp sensor for protection of the laser diode
More expensive stuff.
Hopefully I don’t blind myself.
Lovely eyewear… I hope it does the job it was created for.
Be Safe! …but have fun.
It was like $50 and apparently much better quality than the cheap ones you can get form china, so it better be
Be gracious and don’t be surprised if someone mistakens you for Elton John and asks for an autograph.
hahaha
I’m already dazzled.
. . . More expensive stuff. Hopefully I don’t blind myself.
Nice. Looking forward to watching this build. No g-ball lens built into the can. 7 watt 450nm diode from a NUBM44/47 bank?
Thanks, yeah its a nubm44
I hope that mount has the right tolerances to press fit the diode, otherwise you get thermal issues
also a TEC cooling is needed to keep the diode cool if you want to drive it hard
I’ll heatsink the diode with thermal paste or liquid metal.
I’ll be making my own mount for the diode so I can probably do pressfit too.
With a large heatsink you can do 6-7W without a tec, see some of the videos on youtube.
A tec is more necessary for 8-10W which is pretty extreme.
I’m trying to keep the amount or parts minimized for highest reliability and lowest price, so that means no liquid cooling or fans or tecs.
Just tested the laser tonight, incredibly powerful, was at minimum power and it started burning a hole in some cardboard.
Unfortunately I seem to have some issue with my laser driver, so just using my DPS5020 power supply to drive the laser at constant voltage and it works great.
Planning to machine a custom copper heatsink for testing purposes, as I need to hold both the collimation lens and crystal at fixed distances.
My idea is to make a simple rectangle block that I can screw onto a CPU heatsink like the NH-D15 for some extreme cooling:
Then I can also make a second attachment for LED MCPCBs and I can easily switch my heatsink to whatever needs to be tested.
I also just purchased a special M9x0.5 thread tap (for the lens) to make the copper laser block.
Find many great new & used options and get the best deals for Metric Fine Mf M 9 x 0.5 9 mm Hand Taps Serial Form at the best online prices at eBay! Free shipping for many products!
Please take care of you
and the outside world!
Regards Xandre
Then I can also make a second attachment for LED MCPCBs and I can easily switch my heatsink to whatever needs to be tested.I also just purchased a special M9x0.5 thread tap (for the lens) to make the copper laser block.
Metric Fine Mf M 9 x 0.5 9 mm Hand Taps Serial Form | eBay
It looks like you’re finally starting to get sumwatt more serious about this little project.
:laughing:
M9 is an unusual size. Never heard of it before now. Good to see more components rolling in. Hopefully the driver can be sorted out.
