If you want 26650 size, a reflector type of beam pattern, and high output (over 2,000 lumen, you would need to look at the many xhp50.2 and xhp70.2 lights that use a boost driver. There are like 20 of them or more. They are getting popular. In my sig I talk about the ODF30 and SP33 (I really like the SP33).
If you don’t care about a reflector style beam pattern, you have a lot more choices with lights using a TIR lens. Some use boost drivers, some don’t. The many leds can be wired in different ways.
I know there was a problem with the driver from the first c8f 21700 that didn’t reach the claimed lumens, and sofirn released a second version of the driver
Maybe this light is using the first underpowered driver?
I don’t think there was ever any problem with the driver. There might be a lack of current flow through the retaining ring. Maybe glue on the threads? Adjusting it gave me a boost in output. Also changing the led wires can give a boost.
It will not hit 3500lm stock. I think they over rated it. About 3,000lm stock seems right.
Being a FET driver, the output can vary a lot based on the battery. What battery are you using? How are you measuring the lumens?
Both Sofirn and GearBest have confirmed that Utorch C8F will not have previous Sofirn issue. My C8F from very first batch did produce 3300lm with my VT5A.
