[GB ended,discussion only] CRI > 80+ NICHIA 2000K-6500K [E21A/219B/219C/319A/144A/757GT-F1(Optisolis)]
1609 posts / 0 new
virencelights
virencelights's picture
Last seen: 21 hours 35 min ago
can this be still ordered?.
cheers
Virence ArmyTek Viking Pro Quadtrix 9080 E21A 5700, Virence Skilhunt H04 Quadtrix 9080 E21A 5000k, Virence Jetbeam AAA 9080 E21A 5000k,
Virence Jetbeam AAA Nichia HCRI Red Led.
clemence
clemence's picture
Last seen: 4 hours 36 min ago
cheers
There are currently still six three pcs Tiara left in the store: https://www.virence.com/product-page/Custom-TiaraC1Pro-4xNichiaE21A-R9080
- Clemence
virencelights
thanks , sent you a PM my friend.
adam7027
Last seen: 2 days 18 hours ago
clemence wrote:
cheers
- Clemence
That page says me, that you have the 3000K CCT E21A emitters to include them in that customized Tiara C1 Pro, but on the separate page for E21A, I still cannot select 3000K for E21A (approx. since at least 3.5 months).
Now, this means, that I can buy Tiara C1 Pro with that emitter, even if you don’t have that for separate purchase?
clemence
clemence's picture
adam7027 wrote:
clemence wrote:
cheers
- Clemence
Yes, I keep those 3000K prioritized for those Armyteks first until I place another order to Nichia. I only have less than 50pcs ATM
- Clemence
clemence
clemence's picture
@HICRI9080: I think you misunderstood the situation here Wink
I sell a complete ready to use modified Armytek Wizard and Tiara, not just the host or parts (you can if you want it). The picture of a box with some half finished headlamps inside was just to show our friends who ordered them in November – December about the progress I’m currently at.
- Clemence
virencelights
OK I saw Wizard Pro out of stock.
clemence
clemence's picture
UPDATE 181212: (Regarding the E17A/E21A/Optisolis AAA)
I still can’t give the exact pricing but it won’t be no less than USD 25. Some of the components and the lights are still under Indonesian custom inspection. I will launch it as soon as I finished with the test.
Some preview:
- Jetbeam Jet-μ based
- 3 modes: 0,5lm – 20lm – 80lm (estimated) with mode memory
- 3 different TIR optic choices included in the package
- LED options: red/green/blue/amber (E17A), 2000K/3000K/4000K/4500K/5000K/6500K (R9080 E21A), 2700K/3000K/3500K/4000K/5000K/6500K (Optisolis)
- No glue nor thread locker, super mod friendly
- Possibility of reprogramming with PICKit for those with skill
- Clemence
djozz
djozz's picture
Last seen: 1 hour 25 sec ago
Cool
SKV89
Last seen: 40 min 53 sec ago
This is a GREAT and CHEAP opportunity for those that want to try out these exotic emitters, which I think are the current best in the world in terms of tint and color rendering.
adam7027
If Optisolis is an option, then I will definitely in for them Party
fixed it
Last seen: 2 weeks 2 days ago
I look forward to that as well. The only problem will be choosing which one(s).
Oh and our local post finally delivered my order from months ago (they were on rotating strikes and not processing international mail very quickly). Congrats on the most impressive packaging I’ve ever seen.
clemence
clemence's picture
That’s always been a problem with economy service from and to Canada. Even the EMS can’t deliver most packets timely as promised to Canada. Enjoy your LEDs =)
- Clemence
clemence
clemence's picture
clemence
clemence's picture
As requested by Ryzbor, here’s your finished Wizards and Tiara:
- Clemence
Pavlo
Last seen: 7 hours 49 min ago
Golden goodness!
SKV89
I have several Tiara Pros 4x E21A of different color temps modded by Clemence. They are really amazing. Regulated output, very efficient, and beautiful tint. I use them everyday.
electricjelly
electricjelly's picture
Last seen: 4 days 9 hours ago
If I put a 18650 tube on a Tiara C1 pro will it be the same as a Wizard Pro? And would the headband clip that comes with the tiara fit the 18650 tube?
clemence
clemence's picture
It will just look like a Wizard Pro, outputs the same as Tiara, last approximately three times longer than Tiara Pro.
This is my favourite setup for these reasons:
No thermal step down even at its highest mode (T2), no overheating, much longer runtime than Wizard Pro too. In Wizard Pro the Turbo 2 can only be used temporarily while in Tiara, the Turbo 2 can be used continuously until the battery ran flat*.
  • Nnewer Tiara C1 Pro with cooling ribs.
- Clemence
SKV89
The Tiara C1 Pro with 18650 is the same setup I use most too because of the much longer run time and no stepdown (or takes very long) due to the increased mass and surface area of the longer tube to reduce heat gain speed and increase heat dissipation rate. I use the 18350 sometimes when I want a super pocketable light, which I use for night time picture taking. The HI CRI light is way better than the flash on smartphone cameras and much brighter.
clemence
clemence's picture
UPDATE 190301: Store news
- A new batch of E21A order placed to Nichia two days ago. There will be full line-ups of E21A coming. ETA, mid March
  • sm203 (R9050),
  • sm223 (R9050),
  • sm273 (R9080),
  • sm303 (R9080),
  • sm353 (R9080),
  • sm403 (R9080),
  • sm453 (R9080),
  • sm503 (R9080),
  • sm573 (R9080),
  • sm653 (R9080)
- Hopefully triple Carclo compatible E21A MCPCB can also keep up not long after. Still need more funds for that.
[Clemence]
Agro
Agro's picture
Last seen: 1 min 3 sec ago
Clemence, would it be feasible to factory drill optics holes in mbpcb so the lens sits lower?
clemence
clemence's picture
Don’t worry, I actually did the test investigating the possibility of the new VR20SP3. The focus will be adjustable by shimming.
[Clemence]
staticx57
Last seen: 8 hours 21 min ago
Clemence, since you have not made the triple e21a, can we wishlist individual addressable LEDs on it? Big Smile
clemence
clemence's picture
Done! It’s seriiies/parallel/iindiividual addressable
[Clemence]
adam7027
  • sm203, sm223 (R9050),
  • sm273, sm303, sm353, sm403, sm453 (R9080),
  • sm503, sm573, sm653 (R9080)
[Clemence]
Good news Thumbs Up , I will be probably in for several of them.
Can you make it Jaxman E2L compatible (I mean, leaving the possibility of sanding of the edge of MCPCB to make it only 19mm diameter)?
Also, will there be VR20S1 MCPCB as well (for both single E21A and 144AM)?
clemence
clemence's picture
[Clemence]
Can you make it Jaxman E2L compatible (I mean, sanding of the edge of MCPCB to make it only 19mm diameter)?
19mm is not a common size. It’s better I custom make it from VR20SP3, there should enough margin to do that.
No plan for VR20S1, after this VR20SP3, the next MCPCB will be VR38SP16,
Tip: You can convert existing VR21SP4 to single E21A use by scraping the solder mask.
[Clemence]
adam7027
[Clemence]
I’ll jump-start for the VR20SP3 then Smile
virencelights
thanks Clemence.
SKV89
VR38SP16 will be insane! Gonna get some of your new creations from you for sure.
