[GB ended,discussion only] CRI > 80+ NICHIA 2000K-6500K [E21A/219B/219C/319A/144A/757GT-F1(Optisolis)]
That page says me, that you have the 3000K CCT E21A emitters to include them in that customized Tiara C1 Pro, but on the separate page for E21A, I still cannot select 3000K for E21A (approx. since at least 3.5 months).
Now, this means, that I can buy Tiara C1 Pro with that emitter, even if you donā€™t have that for separate purchase?
Yes, I keep those 3000K prioritized for those Armyteks first until I place another order to Nichia. I only have less than 50pcs ATM
- Clemence
@HICRI9080: I think you misunderstood the situation here :wink:
I sell a complete ready to use modified Armytek Wizard and Tiara, not just the host or parts (you can if you want it). The picture of a box with some half finished headlamps inside was just to show our friends who ordered them in November - December about the progress Iā€™m currently at.
- Clemence
OK I saw Wizard Pro out of stock.
UPDATE 181212: (Regarding the E17A/E21A/Optisolis AAA)
I still canā€™t give the exact pricing but it wonā€™t be no less than USD 25. Some of the components and the lights are still under Indonesian custom inspection. I will launch it as soon as I finished with the test.
Some preview:
- Jetbeam Jet-Ī¼ based
- 3 modes: 0,5lm - 20lm - 80lm (estimated) with mode memory
- 3 different TIR optic choices included in the package
- LED options: red/green/blue/amber (E17A), 2000K/3000K/4000K/4500K/5000K/6500K (R9080 E21A), 2700K/3000K/3500K/4000K/5000K/6500K (Optisolis)
- No glue nor thread locker, super mod friendly
- Possibility of reprogramming with PICKit for those with skill
  • Clemence
:sunglasses:
This is a GREAT and CHEAP opportunity for those that want to try out these exotic emitters, which I think are the current best in the world in terms of tint and color rendering.
If Optisolis is an option, then I will definitely in for them :partying_face:
I look forward to that as well. The only problem will be choosing which one(s).
Oh and our local post finally delivered my order from months ago (they were on rotating strikes and not processing international mail very quickly). Congrats on the most impressive packaging Iā€™ve ever seen.
Thatā€™s always been a problem with economy service from and to Canada. Even the EMS canā€™t deliver most packets timely as promised to Canada. Enjoy your LEDs =)
- Clemence
Trailerā€¦ā€¦ :partying_face:
As requested by Ryzbor, hereā€™s your finished Wizards and Tiara:
- Clemence
Golden goodness!
I have several Tiara Pros 4x E21A of different color temps modded by Clemence. They are really amazing. Regulated output, very efficient, and beautiful tint. I use them everyday.
If I put a 18650 tube on a Tiara C1 pro will it be the same as a Wizard Pro? And would the headband clip that comes with the tiara fit the 18650 tube?
It will just look like a Wizard Pro, outputs the same as Tiara, last approximately three times longer than Tiara Pro.
This is my favourite setup for these reasons:
No thermal step down even at its highest mode (T2), no overheating, much longer runtime than Wizard Pro too. In Wizard Pro the Turbo 2 can only be used temporarily while in Tiara, the Turbo 2 can be used continuously until the battery ran flat*.
  • Nnewer Tiara C1 Pro with cooling ribs.
- Clemence
The Tiara C1 Pro with 18650 is the same setup I use most too because of the much longer run time and no stepdown (or takes very long) due to the increased mass and surface area of the longer tube to reduce heat gain speed and increase heat dissipation rate. I use the 18350 sometimes when I want a super pocketable light, which I use for night time picture taking. The HI CRI light is way better than the flash on smartphone cameras and much brighter.
UPDATE 190301: Store news
- A new batch of E21A order placed to Nichia two days ago. There will be full line-ups of E21A coming. ETA, mid March
  • sm203 (R9050),
  • sm223 (R9050),
  • sm273 (R9080),
  • sm303 (R9080),
  • sm353 (R9080),
  • sm403 (R9080),
  • sm453 (R9080),
  • sm503 (R9080),
  • sm573 (R9080),
  • sm653 (R9080)
- Hopefully triple Carclo compatible E21A MCPCB can also keep up not long after. Still need more funds for that.
[Clemence]
Clemence, would it be feasible to factory drill optics holes in mbpcb so the lens sits lower?
Donā€™t worry, I actually did the test investigating the possibility of the new VR20SP3. The focus will be adjustable by shimming.
[Clemence]
