Lumintop EDC01 is a mini keychain LED pocket AAA flashlight which emits a max 120 lumens with Cree XP G3 R5 LED by a single AAA flashlight. Four color options, tail standing ability, twisty switch operation, mini in body size, IP68 rated protection, EDC01 is the best for your every day carries, as well as a multi-function lighting tools.
Main Parameters:
Emitter Type: XP-G3(R5) LED
Max Output: 120 Lumens
Range: 37m
Peak Beam Intensity: 553cd
Battery Configurations: 1 × AAA battery
Working Voltage: 0.9-1.5V
Waterproof: IP68, underwater 2m
Impact Resistant: 1.5m
Output and Runtime:
Low: 5 lumens ( 36h )
Med: 32 lumens ( 4h )
High: 120 lumens ( 30min )
Product Features:
● Utilizes Cree XP-G3 (R5) LED with 50,000 hours lifetime.
● 3 modes with a max 120 lumens output and an up to 36 hours run-time.
● Runs on one always available AAA Ni-Mh or Alkaline battery.
● Compact and light-weight design, easy to carry.
● High-efficiency digitally regulated circuit maintains constant brightness.
● Bead surface optical lens for soft and balance beam.
● Glow-in-the-dark O-ring and optional diffuser easily locates the light in the dark.
● Simplify twisty switch makes it easy access all modes.
● Capable of standing up on a flat surface to serve as a candle.
● Make of aircraft-grade aluminum alloy with wear-resistance painting.
● IP68 rated protection, impact resistance to 1.5 meters.
Four colors optional of on GearVita, blue, pink, purple and golden, the exquisite package fits for applications such as gifts, EDC, tools etc.: https://gearvita.com/lumintop-edc01-mini-flashlight-120-lumens.html
Hot sale products:
oneplus 6t 256gb
yi 4k action camera floating grip
