PL47 arrived. First impressions …
Strange shape. The tube fits Lii40 and even has a minimum stock. Anodizing almost perfect, traces on the head. The edges could be smoother. The switch works perfectly, much better than on GTmini. It is a pity that you can not turn off the backlight. I turned off the AUX diodes because somehow I’m not doing these things. The centering of the LED minimally flies sideways. Contacts a bit dirty.
Let’s go to the data:
Dimensions 88x40mm
Weight with Lii40 150 grams
LED: SST-20
Color 3872K
What’s most important and many of you are waiting for this information, BIN, 5D2, so under the BBL line
Power consumption 9A
36W power
Lumen 2520
Descent down after 20 seconds reaching 1200 lumens
Lux 17090
Range 261m
Angle of 25 degrees so a minimum wider than D4S with HP-L HI.
Disadvantages:
Sharp edges of the head
Bad headband
It warms up very quickly, like D4 from Nichia
It crushes batteries 21700
Benefits:
Color, CRI, under BBL
Ui ramping
Power
