It’s only rear switch?
Just placed an order for the SST20 3000k. Nightwatch makes great host. They have good finning and enough mass to handle high output like a champ. I might swap in a White Flat on this one since the max current is 5A for this.
tatasal would you please check is it available option 21700 as in the product detail
// If you want to use 21700 battery,pls choose the option 21700 //
thanks
Ok, l will check.
Edit: Dec. 12
In the drop-down selection for led tints, at the bottom of the list of led tints is the $3 21700 tube.
Any idea when these will start shipping?
Do you have the runtimes on high and turbo?
This Sunday.
Edit: All unshipped orders will be shipped out today, Friday.
NS22 SST20 3000k:
Ordered SST20 6500k
Thanks
Wow. Simply put, that is impressive throw for a 3000k 95CRI emitter.
Do you have a beamshot for the 4000k version? It would be awesome if you could take/have one.
anyone knows how this compares to the Astrolux C8? I know i can see at least 560m with the Astrolux with room for a little further
tatasal, howcome I don’t see that gray color option. I was thinking about replacing the emitter with the White Flat but seeing that beamshot with the 3000k SST-20, which is what I ordered, it’s making it a hard decision.
Also interested in a gray color, where are the options?
I’ve put a 95 CRI SST-20 in two different lights that originally had an XP-L HI. One was regulated, and the throw was the same. The other, an Astrolux SS has a FET driver, and both power consumption and throw increased. I get 434m (47 kcd). This light has a larger head and reflector, so I’d expect more throw.
1250lm is a fair bit more than I get from 5A, so I imagine those numbers are for low-CRI. I’d expect over 1000 lumens and over 500m from high-CRI though.
What sort of driver do the 3 volt versions use?
BLF A6, nw: ————————————————————————————— NIGHTWATCH Seeker NS22 3000k, 95cri:
The NS22 below the BLF A6:
Just ordered 1 XHP50.2 5000k, 1 SST40 and 2 21700 tubes.
Seeker NS22 3000k, 95cri ———————————————————————- Nitecore EA41 cool white
Received SST40 and XHP50.2 and 2 21700 tubes. Fast shipping, 8 days! Very nice lights. Just slightly smaller than a C8. Head OD is 3mm smaller. SST40 tint is nice, looks more white than blue to my eyes. Thanks for a great deal.
Dang, that was fast ! Still waitin on mine .
Can someone post a pic of the light with the 21700 tube on? Would it take the protected Rofis 21700 that is almost 75 milimeters?
