[♛ FreemeGB] Fireflies PL47 Gen II 4*XP-L/ Nichia/ SST20 Hi CRI 21700 Right Angle Flashlight - ENDED
Has Anyone also noticed that the clip is difficult to hook on a pocket? Because the clip ends just before the tailcap. So the tailcap covers the clip kind of, takes a bit of fiddling to hook it on… I suck at explaining things in english… sry
So i find it rather difficult…
have the same issue regarding the optics
Album — Postimages big pics.
They have pits/dig marks in and looks like a pin is snapped too…
Just few pics of mine next to my other EDC’s it performs well without any problems, fun and pratical for me :+1:
That sure was a lot for such a simple question.
I was looking for “I have not received mine yet as well.”
What’s going on Tom Tom? Bad day?
Best wishes buddy, hope things get better for you. I have prayed for you already.
When I unscrew the battery tube a little to lock out the light a very brief and tiny red flash occurs from something near the centre of the lens. Can anyone explain this phenomenon?
HONDARIDER
My order is with yours. I received this notice:
from USPS
Red aux LEDS indicate a low battery on all FireFlies models. ToyKeeper could explain it better but basically They blip as you cut power. If you hold turning the tube or tailcap at the point where the torch barely gets any current, just before lockout, the red may actually stay on because it’s reading low current. I should say voltage, not current. The red aux indicate low battery voltage. That’s all, it’s a good design.
I also ordered the E07 from Neal with red aux LEDs. Interestingly, red is not an option when ordering directly from FireFlies. Is it an exclusive for Neal’s site?
On Nov 19 I got a notice saying: Your item was picked up by a shipping partner at 10:07 pm on November 18, 2018 in FREMONT, CA 94538. This does not indicate receipt by the USPS or the actual mailing date.
Nothing since. I ordered SST-20 also, if that has anything to do with it.
My Gray E07 ordered from Neal hasn’t shipped yet. I expected when I placed the order that Neal would not be getting a shipment of units from FireFlies until after they’ve shipped out the first batch of their own orders.
Mine is on the way. I ordered the Nichia 219B version. I have a Samsung 50E 21700 but reading back through this thread, it doesn’t seem to fit well. Does anyone have a recommendation on a 21700 battery to use in it that’s suitable for the 219B.
Many thanks for the illuminating replies- I am always impressed with the breadth of knowledge available here.
My PL47, not ordered through this group buy, showed that it landed in Denver Colorado, then went to Chicago, and now it’s off the grid again with no guesstimate as to when it should be here. But hey, it’s active anyway! lol
I tried using the Sofirn 4000mAh 21700 (this came with the Sofirn C8F 21700 bundled kit, as Sofirn cannot ship bare batteries to my country) on my Fireflies PL47 and they fit, although it’s a relatively tight fit…
Same here, no issues with Sofirn 21700 on mine. Got black SST-20 4000K.
Two more observations, look carefully, at around the 4 o’clock position, and I think I see a green wire trapped between the edge of the driver and the head. Also displacing the driver sideways. Maybe even a black wire as well.
I don’t see any witness marks on the driver or tail PCB contact rings, where the ends of the tube should have been making firm contact. Perhaps the torch is too new for these to have developed yet.
These witness marks were useful to study the poor contact problems of the first batch Q8, and might also be useful to study for those with PL47 issues. In the Q8, some went so far as to try inserting a ring of solid copper wire, to improve marginal contacts, and/or smoothing the uneven surface of the first Q8 tubes using e.g. some fine grit sandpaper on a flat piece of glass.
Ideally the witness marks should be even, and continuous over the full circumference, once developed.
Also consider simply measuring the length of the tube, the length of your cell, then the compressed length of each spring (that’s the tricky one), and do the calculation.
I still don’t like the look of the soldering of the springs to the PCBs, I see little evidence that the solder has wetted, or that there is sufficient quantity.
PS:, my apologies to the forum for being even grumpier than usual, and taking it out on some of you. Yes, I have been having to cope with a truly stressful situation for many months. But that’s no excuse.
Thank you for being so patient and tolerant.
Complaining at 1k posts, most do a giveaway! Lol call it like you see it Tom tom!
See post 1382. The black lights and the gold lights have different tube dimensions.
As it’s my first multiemiter TIR flashlight I’m not sure how optics should look like so I’m just gonna post this pic and you tell me.
Like I said - my first quad flashlight and actually first with semi-clear optics. The beam is nice and even so not a real-life issue. Was just wondering if it looks simmilar in D4/D4S.
