[Available again! - BLF special edition light] new Sofirn AAA twisty high CRI 5mm LED
Thanks for the excellent data, as always.
I haven’t seen a hotspot in the handful of uninstalled Yuji’s I have, so I think the spots multiple users have documented are due to the “reflector” that isn’t really intended as such. When I get mine, I might try painting the reflector on one white to see if that smooths it out.
I’m also surprised to see how much difference there is between your 3200K samples. Comparing your chromaticity diagram to the datasheet, the rosier one should be well-inside the F8-1 tint bin, but the other one might actually fall in the F5-1 bin.
Regardless, every Yuji I’ve seen, from a couple different batches, has looked great, so this doesn’t ultimately affect my eagerness for the C01.
Very cool! I would love to try an Optisolis or E21A light in a couple different color temperatures.
Same here, I would not mind as a Christmas gift a set of Clemence’s Jetbeam mods with all available Optisolis colour temps.
just got mine in today. 5600k is a really nice color. it came in a cute tiny box lol.
So where to buy a magnet and tritium insert for the rear?
I’m really digging the warm Yuji now in the evening. It brings out the orange in a pair of Fiskars scissors perfectly. Almost as nice as a Viltrox LED panel.
Continuing off-topic, if I can be forgiven for doing so for a moment, I’ve got an even more exotic idea, although definitely beyond the scope of what Clemence is doing: a two channel quad with tint-ramping between 2700K and 5600K or so.
Presumably the driver could be similar to the BLF lantern, but as a floody flashlight or headlamp. Something D4-like (probably 7135 based, not FET) would be awesome. If a cluster arrangement like the VR16SP4 could work to enable something closer to the Olight S1 in size, even better.
Ok, sorry for fantasizing for a bit. Back to the C01 - I’m still hoping the color versions show up soon.
thanks for the spectral info
great to see that the 5600k has such high R9
I also love the Warm Yuji, when my brain is white balanced to the Incandescent light in my house.
I think you might be right that the hotspot is caused by shiny reflector cone. I suggest you make it Flat Black, not white. Maybe sandpaper would reduce the reflectivity of the silver cone. I am not suggesting sanding the LED dome.
I tried a test, using black electrical tape, and it did reduce the hotspot.
But not completely, maybe because the tape did not block all the shiny cone at the bottom of the reflector, around the led itself. Or because the tape itself is shiny…
result, inconclusive, but suggests that blacking out the reflector cone may be a good idea.
I managed to remove black paint from the clip. I think it actually looks much better with bare steel.
How did you remove the paint?
Soo… I started off with my nail but then switched off to Spyderco Tri-angle safety guard :wink: - essentially just a brass rod not to scratch the finish. After most of it was gone I just finished off tricky spots with chisel tool from my multitool.
I’d say it’s max 10 min work. Paint is barely holding on it (it’s nicely polished steel underneath).
BLF GT nano edition :wink:
So regarding the Sofirn C01 pocket clips:
Prototype: clip not good, breaks.
First production batch: clip is good, strong.
Second production batch: clip is not good, bends.
Like you already said, chabuduo
Yep. I showed him this thread, and then we had this conversation:
He: “OMG dad! Your profile picture with that small keychain thingy, is … well … not good.”
Me: “But I want to make a statement.”
He: “Here, wait, I will draw you a new picture.”
New generation, digital native.
Quality, not quantity, that is what this light is about.
For more quantity&quality, look for a 4000K SST-20 LED flashlight, google Emisar D4.
Or just order any flashlight that is improved by Virence.
Good to have you on board with the C01 :slight_smile:
And thanks for your measurements, especially for the combined 3200K+5600K chart, that one specifically means a lot to me. :partying_face:
You are a fantastic asset for the flashaholic community.
I have received all my 5 lights from the interest list now: of my 4 3200K C01, 3 are above BBL and only 1 is rosy tinted.
So tint lottery is a trait the Sofirn C01s share with the Zebralights :person_facepalming:
I do agree with iamlucky13 here, even my C01s with above BBL Yuji are still great in actual use.
And miles ahead in light quality of any other 5mm LED flashlight that is commercially available right now.
Great idea! You identified a trend which will become available in commercial flashlights in due time. There is a Japanese brand of lanterns that already does exactly this (can not remember name right now). You already see it in other domains: IKEA is selling cheap LED lights for fixed armatures that can change to a warmer CCT when dimmed down.
Ah, I see, the mechanical way.
Well, that is sort of good and bad news: the good news is that the paint comes of easily if you want a shiny silver clip, the bad news is that the paint comes of easily...
I think a bare metal clip (without paint) would have been nicer (perhaps Sofirn could switch to unpainted silver clips for the next batch).
[quote=slowtechstef]
Mine is also soft. maybe if i heat it up to red hot and then cool it down in water or oil the metal will harden a bit. will try that tomorrow.
[quote=polarweis]
One thing is for sure, it will not hurt to try. It is worthless as it is. :wink:
About the weak clip, we talked with the supplier who told clips are from the same mould, so it might be different material. The QC workmake will talk with the supplier seriously today and resolve this issue.
Furthermore, we were suggested to use new led of yuji which is more powerful than the existing 5mm but without legs
https://store.yujiintl.com/collections/frontpage/products/bc-series-high-cri-small-angle-led-smd-5555l-pack-1000-pcs
no, but you can get a Peak Eiger that can do that :slight_smile:
You have done a fantastic job of building a high CRI light, with a choice of two color temperatures, and for a
very low price.
Thank You!
thanks for the link to the Yuji LEDs, it gives lumen values
existing C01 LED: 6.1-8.8 lm
alternative LED: 18-22 lm
suggestion:
The 18 lumen version would be really cool with a QTC, like the Eiger uses .
But skip the LiIon compatibility, to keep the cost down… I dont need 100 lumens from AAA… 20 is plenty for what that little light needs to do.
I wonder if there is interest in a Special BLF group buy for a Copper Sofirn C18 with QTC? :wink:
Infinitely variable from 0-20 lumens, at the twist of your fingers… whats not to Love?
Beamshot required!
Actually, the Djozz dedomed style would probably work best for this, but I don’t suggest doing that to your light.
[quote=teacher]
Depends on the material. There’s a good chance it only gets very brittle and snaps at first use.
It is for a reason that the Dutch version of the expression “the tricks of the trade” is “het geheim van de smid” (the secret of the blacksmith). :wink:
[quote=iamlucky13]
Beamshot required!
[quote=polarweis]
1m to white door. the bright white ball is the reflection. pretty nice throw :smiley:
[quote=Henk4U2]
Very true Henk4U2. :+1: …. But it is worthless as it is, so on the offhand chance it might work, it won’t hurt to try.
Tempering after this makeshift ‘heat treating’ attempt might well relieve some of the brittleness.
If you do try it polarweis, let us know the outcome please.
